Question about KitchenAid KBMS1454R Microwave Oven
Kbms1454r clock flickers and it shuts off and comes back on while trying to cooking things. it does this repeatedly.
Re: kbms1454r
RE: clock flickers and it shuts off and comes back on while trying to cooking things. it does this repeatedly
RE: while running it turns on, off,, off. It does heat things, but takes longer, obviously, so I don't think its the magnetron tube being that it does heat. The display blinks a little bit also. Have 12 kids and NEED a working microwave!!!! Any help? Thanks SO much!- bcdkbbgbw
Had Kitchenaid repair look at it and they said cavity thermostat..replaced it, worked fine. 4 months later...same problem!!
Posted on Jan 21, 2010
  • 100 Answers
Re: kbms1454r
Your magnetron is leaking and needs to be replaced.
Posted on Oct 31, 2007
0 characters
3 Points
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Periodically the VFD display will start to flicker while cooking, usually resulting in it resetting - stops cooking and all the VFD elements light up. It won't restart a cook cycle until I set the time and...
See this FixYa solution, even if your model number is different.
Dec 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs for about 2 seconds then shuts off, then comes back on, then on, off, etc. Takes forever to just run 20 seconds, heat works but not efficiently. Clock flickers, too, and runs slow. Took...
Since the clock flickers, I would investigate the receptacle you have it plugged into as it or the circuit may be intermittent. This COULD even be a fire hazard. If the receptacle uses those push in wiring, get rid of it and replace with one using screw terminals.
Nov 18, 2010 | KitchenAid KBMS1454R Microwave Oven
Clock/timer light elements are burning out in my kitchenaid microwave model KBMS 1454R. I need the procedure for replacing the clock/timer display.
should come in the package with replacement parts. With whom do you deal? Is there a Johnstone Supply near you?
I have found a great resource on the WWW for otherwise obscure answers at They have the parts you require and they have a answer guy there that is as good as a auto parts counter guy.
I hope you have found some value in these comments.
Sep 23, 2009 | KitchenAid KBMS1454R Microwave Oven
Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
Trouble shoot microwave
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Also, are any other of your electrical items (light bulbs, DVDs, etc.) failing lately? This could indicate improper power line voltage.
Let us know if the hard reset doesn't fix it.
Jul 18, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Please try on some other power point as if there is loose contact or sparking in point which cause to switch off as soon as you start because of heavy current drawn by oven and clock also resets. If not solved even then must have some short circuit or over loading in timer circuit or magnetron. in this case you have to call for a service engineer.
Jul 26, 2007 | GE JVM1860 Microwave Oven
Microwave shuts off after 2-5seconds
The problem is most likely the magtube, it takes aprox 3 sec for the tube to energize and then it kills the microwave. If you drop the control panel away and start the microwave 90% of the time it will cook fine.
Nov 19, 2006 | Emerson MW8102SS 1100 Watts Microwave Oven
We own a GE Microwave jvm1653sh01
The first thing I would check would be the magnetron TCO (thermal cut-out). This is a little safety devise that protects the magnetron in the event of overheating. These can act up even without overheating. I believe the nuetral side of this TCO runs through the board, and therefore the flickering and shutdown. When the TCO cools, it resets. If it were the door switch, you would blow the fuse and wouldn't be able to set the time without changing the fuse. There are other cavity thermostats that could be the culprit but my quess is on the magnetron TCO. When working with microwaves always unplug the unit and discharge the capacitor. This is high voltage..Good Luck
Jun 11, 2006 | GE JVM1651 Microwave Oven
KitchenAid KBMS1454R Microwave Oven Logo
224 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Barrett Palumbo
Barrett Palumbo
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
