FixYa.com
Tags:
U.S. Robotics MAXg USR5461  Wireless Router
Vpn pass through problem with us robotics model...
posted by izzydog on Oct 29, 2007
when my work laptop is connected directly to my home DSL Modem, I can connect to my employer's network using Cisco VPN Client. When the laptop is linked to my home USR5461 either wireless or wired,  I can connect to internet but cannot connect to employer network using Cisco VPN client. what can I do to remedy this issue?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 13, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
solved the problem. Had to set DSL modem to bridge mode and then set the router PPoE, provide ISP name and password information and bingo! works!!
izzydog
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
is it possible that DSL router needs you to add the rmote network to your trusted networks?
Solution #3
posted on Oct 30, 2007
Not Rated (0)
rocker ramji
Rank:Wiz Wiz
Rating: 78%, 182 votes
login to the router and check these things
IPSec Passthrough: Enable Disable               PPTP Passthrough: Enable Disable               L2TP Passthrough: Enable Disable
Comment by rocker ramji, posted on Oct 30, 2007
or u need to open some ports on teh router>rate me solved if its help full
Can you Help with these Routers problems?
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
