You don't actually say what's happening!
So the only advice I can give is that in stereo amps the two channels are the same. So if you are testing it you can compare the left channel with the faulty right. So a voltage reading on the left should match in the same place on the right. You can also touch the amp with an insulated tool. While switched on it will buzz on the channel in question. So if it buzzers on the left then it should buzz on the right. Touching parts of the amp in this way will quickly tell you what works and what doesn't.
SOURCE: Can I remotely control speaker outputs on the Marantz PM 8003?
HI...
You need an 8 ohm stereo "L-pad"
Try partsexpress.com
or
mcmelectronics.com
SOURCE: Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
SOURCE: sound probem of marantz amplifier at right side.
sure it is not the speaker?
switch them and check
