I am using HP laserjet 3005 since 2 years. recently its teflon torn out and the service person replaced it with Odessay teflon. but now i am facing problem of blur printing on high fuser mode.. please suggest me from where i can get original quality teflon.
The tan and black paper that is coming out of your printer is the Teflon fuser sleeve that has torn and coming apart. The fuser is the part of the printer that melts the toner onto the paper. The Teflon sleeve in the fuser is where the heat comes from. When the sleeve gets worn down it can tear and you get the little pieces coming out like you have. You will need to replace the fuser unit in the printer to correct this issue. The fusers are available from Amazon and other web sites and they are user installable. The part number is RG5-2657 or RG5-2661 either parts number will work in your unit.
Step 1: Take half test page check is there any symptom what you are getting? If yes replace with another cartridge check...( How to take half test: Give fully mattered print command while printing switch off the power remove cartridge take out printed paper check the printed matter on page) Step 2: If found cartridge is OK, 95% suspected Teflon sleeve( a cylindrical sleeve which is coated grey colored Teflon), replace it if available if not replace with new fuser assembly..
Hello Dear
If you are using from last two years then pls replace the maint kit for long life & better print quality.Hp is not providing the teflon & in market you cann't get origional one.
Check the the fuser. Take the back door off the printer and unscrew the 2 screws holding the fuser assembly in the printer. The fuser on the 4000 series all use a teflon sleeve that can rip and cause the type of error you are getting. You can get a replacement fuser on Ebay for about $40-60 if you do find your torn.
I hope this helps, If so please rate our solution.
