We tried to add a 23 or 25 inch flat screen monitor, it didn't work. But since then I can't get windows xp to run it keeps freezing up. I did control delete alt, didn't work. So I tried it in safe mode and it does fine with the exception of the Icons are super big as well as the text. I went to display and changed settings but they won't stay changed.
Tammy from Tennessee
Go into Safe Mode navigate to Accesories then go to System tools
Select System Restore pick a point before you installed the new monitor and let it roll back.
Re-start the system normally
Did you get a CD with the monitor ?, if you did then I suggest that you load that once you are back on line.
Once it is loaded try for a re-install
If the new monitor is a fancy one then it is possible it needs to have some communication with the PC on a regular basis to keep it happy
