Question about Rio Carbon MP3 Player
No content message???
My carbon pearl is almost maxed out on available storage and I used it that way for about a year without any significant problems. However, out of nowhere, when I turn it on and try to listen to any of my music, it tells me that there is no content. None of my songs or artists or playlists or anything shows up. When I go into my rio properties folder it shows that there is no available memory. It's like it's telling me that all the songs are still on there but they just don't show up when I want to listen to them. I have tried resetting the thing but nothing helps. Any help?
  • 8,596 Answers
Re: No content message???
Perform a firmware upgrade as instructed on the rio website - it will wipe everything clean. Make sure the player is fully charged or this upgrade will kill the player.
Posted on May 23, 2008
0 characters
3 Points
Restore factory settings.....
You can go to the root menu of your player and click settings and select restore factory settings. If this option is not available on your player, connect your player to PC. On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format". Contents may be removed by using this function. So make sure to back up your contents.
Feb 24, 2011 | Philips GoGear ViBE Digital Media Player
How do you restore your carbon back to factory settings? i want to completely delete everything but i don't have the software...i havent for quite awhile. can you restore it just using the device itself?...
You cannot restore the player without a computer but by formatting your drive and re-loading the Rio Carbon Firmware, you can reset it to factory settings.
The Developers cut firmware (latest (unofficial) firmware) is still available here:
Jan 31, 2011 | Rio Carbon MP3 Player
Rca pearl th1602-a I turn it on all I get is the pearl emblem and it wont turn off. I have to pull the battery to stop.
My solution to a Pearl TH1602-A stuck on the pearl screen:
Download the firmware upgrade from RCA's website, run it.
Remove battery from Pearl, keep out.
Press PLAY and hold while plugging into USB port,
when "initializing" progress bar moves, let go off play button.
On my windows, it installed some software and asked me to reboot. After the reboot I re-ran the Pearl firmware file and about 30 seconds later the start button was now available.
Click it. However, You will loose your music on the internal storage.
Oct 07, 2009 | MP3 & Digital Media Players
How do u add music to pearl mp3
Plug your Pearl mp3 to a computer then on your computer go to My Computer and then open the "Removable Storage device"
The "Removable Storage device"is your mp3 player. Once you open that, you just need to drag and drop your favorite mp3.
Jun 09, 2009 | RCA Pearl TH1102 MP3 Player
RCA Pearl TH1602 Frozen?
I had the same problem, usually plugging it into the usb port on the pc and verifying the files on the player, then disconnecting the player will solve the problem. Other times i have to reformat the player, if you do that, you will have to put all your music back on. It's a pain, this has happened to me 4 times, I've only had this thing less than 6 months! It was inexpensive, I guess you get what you pay for, but I like having a AAA battery instead of having to remember to plug it in to the pc to recharge every 15 hrs.
Oct 17, 2008 | Teac MP-111 MP3 Player
Rio carbon
Have you tried installing the 3.04 firmware. This should solve your problem without deleting your data and resetting your rio.
Aug 03, 2008 | Rio Carbon MP3 Player
Carbon Pearl: Invalid Argument
Try accessing the rio's hard drive through my computer to see if it can find the songs: they will be in a folder aptly called music within your rio carbon.
If this doesn't help then if it is picked up via my computer you could try wiping and rebooting your rio, read:
You may have to change the firmware for the rio carbon pearl but this is easy to find on their website.
Hope this helps,
May 22, 2008 | Rio Carbon MP3 Player
Can't do anything without message
It has to make a library file of the contents on the player. It uses that file to display the titles and artists when scrolling through the menus and what not. You'll have to format your player in order to clear it up. This will erase everything and then you can put your songs and stuff back on it. Just make sure that when you do you leave at least 4 megs of space for it to make that library file. Here's a link to the manufacturers instructions on how to format the player.
Mar 06, 2008 | Disney Mix Max Digital Media Player
Rio Carbon 5gb pearl transfer problem
hi first of all update uour firmware: also go to Software tab and update your Music Manager i belive this will solve all your problems good luck
May 01, 2006 | Rio Carbon MP3 Player
Rio pearl directory corrupted
first, and this is always good: If available, firmware for the Rio Carbon can be downloaded online. Second, this might be the problem: The Rio Carbon communicates with your computer differently in MTP mode than it does in MSC mode. When in MTP mode, the Rio Carbon cannot display hidden files in folders, cannot allow transfers to the root Rio Carbon directory, and cannot allow the creation of new folders. (Folders can be transferred to the Rio Carbon using drag-and-drop and copy-and-paste methods.) To use traditional folder options, change the Transfer Mode settings to put the Rio Carbon in MSC mode. Last, "..Removing the Rio Carbon from a USB connection before Idle is displayed on the screen may result in a corrupting the player's file system. If for any reason you suspect that your Rio player's file system has been corrupted, reformatting the player will restore the file system to its original state..."
Nov 27, 2005 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
48 people viewed this question
Top Rio MP3 & Digital Media Players Experts
isaac johny
isaac johny
Are you a Rio MP3 and Digital Media Player Expert? Answer questions, earn points and help others
