Question about Roper MHE14XKB Microwave Oven
Roper mw under cabinet light
I have a roper under cabinet MW that mounts under a cabinet and over a cooktop. the cooktop(under cabinet) light burned out. when I changed the bulb, the old bulb and base seperated upon removal and the wires apparently shorted out when twisting the bulb in the loose base. when I put in the new bulb, the light would'nt work. I've checked the bulbs and even used a meter to see if there was voltage in the socket. No voltage. the 20 amp fuse mounted in the unit checks ok and everything else works fine. Is the control board bad ,is there a particular component on the board that will cause this ?
  • 3 more comments
  • kellse Oct 31, 2007
    no voltage on socket terminals, see above
  • kellse Nov 01, 2007
    I saw an add for repairs on any control board for $32.50 but now can't find it. Got any leeds?
  • Anonymous Nov 15, 2007
    i have the same poblem....did u get urs fixed?? if so how ....or did u just live with no light which i think is very annoying....
  • kellse Nov 29, 2007
    I found the problem!!!!
    A short piece of circuit ribbon was burned off of the circuit board on the back side of the board, between the diode on the low light relay and the terminal connector on the board, The ribbon acted as a fuse when the terminals were shorted on either side of the bulb when removing it. A simple fix with a soldering gun.
  • David111111 Dec 11, 2007
    Light inop, has only 4 volts
  • Roper Master
  • 9,098 Answers
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
  • 100 Answers
You probably need to have the receptacle replaced that the bulb screws into
Posted on Oct 31, 2007
  • Mike Kaiser Oct 31, 2007
    Oops sorry looking at the wiring diagram it looks like the voltage and the neutral line both come from the board with nothing inbetween to stop the voltage flow so it looks like you need a new control board.
I have a Kenmore Microwave Hood 721.63653300. I unscrewed one of the light bulbs and the glassw seperated from the base which cased a small pop now the unit will not run. I have check the power to the unit...
All Microwave ovens have a main fuse that is not accessible while the unit is mounted under a cabinet. Drop MW oven and replace the main fuse.
Dec 23, 2017 | Microwave Ovens
I have a over the range mw, the controls work but the fan,light and microwave itself has no power.
If still under warranty--take it back--serious problem. If not a qualified person will have to check the door switch & interior electronics. There is a faint chance that a wire may not be connected inside. If it is over 3 yrs. old --have magnetron tube checked also.
Feb 07, 2011 | Roper MHE13XH Microwave Oven
Westinghouse wmg281sf microwave Microwave (mw) less than 6 months old and after selecting start the mw makes a noise that seems to come from the light and during operation impedes the power source to the...
Hello mbz... Since the operation is impeded, the problem is more than the light bulb. This unit has an internal short, and should be under warranty for the first year. Return it. Joe
Thanks for choosing Fixya!
Dec 16, 2010 | Westinghouse Microwave Ovens
How do I remove my ge jvm 1653 microwave?
Clean out the cabinet above the micro wave and you will find 2 or 3 bolts that secure the unit (MW) to the bottom of the cabinet. They will normally be towards the front of the cabinet.
I always put a towel or cardboard over the surface of the range for protection and a place to set the MW once it is ready to come down.
Have someone either hold the MW up by putting pressure upwards on the front of the MW or take the screws out. (don't forget to unplug the MW)
Gently let the front of the MW fall forward about 6" to 8" and lift the back of the MW upwards and it will release from a mount that is attached to the wall.
You may feel a little resistance as it might be duct taped to the exhaust going up or out the back.
Be aware that these older micro waves can be a little heavy and it is recommended that 2 people are used to do this.
Apr 09, 2010 | GE JVM1653 Microwave Oven
Microwave was run for 4 minutes with nothing in it, and the right side, next to the light, burned, from the covering next to the light upward and down into the panel halfway.
yes it is NOT advisable to run a MW without something in it to absorb the MW energy, this has happened due to the signal being reflected back to the magnetron, which has no doubt failed. You will need to repair or replace. get a "Quote" before proceeding. That way you can tell to repair or replace.
Mar 20, 2010 | Microwave Ovens
Replace the buttons on a kitchenaid microwave Khhs179lss-5
First, you need to uninstall the microwave (MW) from the cabinet by removing the screws that hold it in place at the top. Open the cabinet doors above the MW to locate the screws.
You will need someone to help you at this point in removing the screws and dropping the MW down. Be sure and unplug the MW before you remove the screws.
Next, you need to take the cover/shell off by locating and removing screws A/R. They are mostly across the back and side bottom.
From there on out, you should be able to methodically find and locate the various fasteners that will get to the button pad.
Dec 16, 2009 | KitchenAid KHHS179LSS Convection /...
Door constrained by adjacent cabinent
You need the "Some Other Solution". Do Not mess with the MW Door Hinges! They have been set by the factory to safety requirement to prevent MW Radiation Leakage. Altering Door Hinge could place you and your Family in harm.
Jan 30, 2008 | Bosch HMV9305 Microwave Oven
GE Microwave JE1640 works only when holding the switch
VK, most likely the switch body has become loose and it's out of adjustment. Unfortunately, to gain access to it, you'll have to remove the MW from the cabinet, set it on a suitable work area and disassemble it. Before doing anything like this, please read the following link carefully and ask yourself if you're up to it... http://www.gallawa.com/microtech/safety.html Remove the trim then remove the screws holding the MW. Pull the MW out and rotate slightly to see where it's plugged in and unplug it. Then pull it all the way out. Remove all the aluminum trim from the MW and all the screws holding the cabinet. To remove the cabinet, stand behind the MW and grasp both sides... pull back and up at the same time. Set aside. NOW!!! DISCHARGE THE CAPACITOR AS PER THE INSTRUCTIONS IN THE LINK ABOVE!!! OK, up by the control panel, you'll see the latch/lock assy. (it has 3 brown switches mounted to it). It's held in place by 2 screws, the lower screw is the one you'll be working on. Adjust this by opening and closing the door and watch the action on how it works and make your adjustments as needed. Now, you'll need to test it before reinstalling. Plug it in, BUT DON'T TOUCH ANY WIRING! Now give it a try. If you need to make another adjustment, DISCHARGE THE CAPACITOR AGAIN BEFORE DOING SO!!! Do this every time you plug and unplug! Continue adjusting 'til you get it. Now, there's a chance that one of those switches is about to go bad and the mounting bracket is fine. In this case, those switches are generic... not GE specific. Remove the wiring from the switches and make notes on their respective locations. Remove the switches from the bracket (starting from the top) and label them 1, 2 and 3. Take these to your local appliance parts store and ask for generic replacements, they are cheap... about 5 bucks each. Then replace them in the same order you removed them. And re-test. This will get you fixed, but please be careful working on Microwave ovens. They are dangerous!
Sep 27, 2007 | GE JE1640 Microwave Oven
Roper MHE14XKB Microwave Oven Logo
245 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Mark Cheong
Mark Cheong
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
