Question about Abit KN8 Ultra Motherboard
Motherboard ABIT KN8
Was working fine ,  but one day cannot switch on, changed power supply
changed ram, VGA pci express card   works fine on another cpu, but there  red led on is lighted on motherboard, cpu fan is not working , pls help.
  • pala88 Oct 30, 2007
    CPU fan is clean and heatsink is clean. Tested cpu Fan it works fine with another cpu, the chipset fan also does not work,  there is no beep at all, Power supply fan does not work,  Yes , it absolutely does nothing, replaced power supply it is still the same,  have removed the cmos battery   and replaced
I just lost my fourth KN8 motherboard and it always seems to take out the power supply unfortuneately. One I returned for the 3 year warranty and as a replacement it worked less than a month. These were on 3 different machines(cases and power supplies of various suppliers) so the mother board is the fault.
Will be hesitant to use ASUS boards again even though this may be isolated to this board only.
Posted on Feb 05, 2008
  • 4 Answers
I dont know about the red light, but all main boards these days have a built in protection if the cpu fan quits. check the cpu fan connection, ensure that it and the heat sink are dust free. if still no go. update  your question with exact info..e.g. does absolutely nothing.. how many beeps you hear..how long b 4 it dies.. final note: be careful what you touch.. static can harm more that most think and the oil from touching can retain heat.
Posted on Oct 30, 2007
  • jdhayabusa Nov 06, 2007
    If you have moved your tower just before the no start, check all connections, including the one that connects the board to the power on button.
    I was rereading your first comment,[2nd line]"works fine on another cpu". I may have mis-read it,.. did you try on another motherboard or did you try another cpu on what you have? This is the elimination game. If everything works on another board, the board was the fault. This can be done for any component. Hope this helps.
My motherboard does not accept my RAM upgrade. 4 Go ( 4 * 1 Go). Compatibility is OK, i works with 2 Go. With 4 Go : i can't boot, continous beeps ! My BIOS is the most recent. What can i do...
Hi, you can see the specifications here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=KN8+Ultra&fMTYPE=Socket+939
Try to download a manual.
My guess is that your cpu does not support that amount of ram.
The ram must also be at an equal size.
Your operating system must be a 64 bit to handle
more than 3 gb of ram.
Aug 27, 2011 | Abit KN8 Motherboard
Dell Dimension C5100 Yesterday it was fine and today it turns on but no visual on the screen. Changed monitor that wasn't it, disconnected the video from the on board video output and installed a pci...
you need to open cpu cabinet. Open back cover of cpu then refix the RAM memory. Pull cmos cell from motherboard for 10 minutes then put it back then all settings defaults. Make sure RAM is working fine. Try with another RAM .If you use 2 RAM memory then check with only 1 RAM 1 by 1. Open processor fan and processor then put it back . Clean dust from all parts . Reconnect both connection to harddrive. Make sure motherboard don't touch the cabinet. Remove pci card if any reattach vga card if you use pci vga card.Pull cmos cell cell from motherboard for 10 minutes then reconnect it.Then check. Let me know if you need further assistance. Thanks for using FixYa.
Sep 02, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
After pressing POWER button i get 2 long beeps -- thats all -- nothing on the monitor -- nothing at all ... :( ??
Two beeps means that you need to check your RAM. Try changing the RAM module and see if it working? If you have any display card (AGP/VGA/PCI or PCI express) installed then you need to check that it is properly inserted in the slot in the motherboard. Also check for any loose connections in display card.
Dec 21, 2009 | MSI K8MM3-V Motherboard
PCI-E card does not work, onboard video works fine, this is the second card.
The Abit IP-95 manual doesn't show you how to adjust your bios settings when adding a PCI-E x16 graphics card. When adding a PCI-E card you'll need to adjust a few settings within, Advanced Setup.
Press the delete key on your keyboard every two seconds to load your bios menu. Within Advanced Setup look for, Onboard Device Configuration and open it. Find, Primary Graphics Adapter.
Set this to read as [PCI-E, VGA] save your changes and exit.
Currently your onboard graphics is enabled. You'll need to change this setting to PCI-E first. When you use the onboard UniChrome Pro 2D/ 3D Graphics & Video Controller you are also using some of your system memory to run the UniChrome graphics. Once you enable the bios to boot to the PCI-E card you can also stop using your system memory assigned to the UniChrome card. Link to Abit is provided below, click on it to open;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=IP-95&fMTYPE=LGA775
Cheers!
Mike
Nov 12, 2009 | Abit IP-95 Motherboard
No boot
if you had received a cd with the card that contains drivers i would replace the old vga card and, assuming it boot s okay, load the CD. after this shut down, swap cards, then reboot.
Feb 07, 2009 | Abit KN8 SLi Motherboard
Have abit - kn8 put 2 gig memm in powered up no picture think I have wrong video card do you know proper one
Hey there,
As per ur question, this problem occures due to following reason:
1. When ur data cable of ur monitor is bad : Try another data cable this causes only to blink LED of ur monitor which not allows any graphics to display.
2. Your RAM can also be responsible for this problem: If your RAM goes Bad then it doesnot allow any graphics file to load and thus causing not to display anything on ur monitor screen as well as ur system keep restart at POST (Power On Self Test) Operation (When VRAM driver is not loaded.
and the last reason is:
3. Your system is not able to recognise your Graphics card due to Either IRQ inteferance or ur graphics card hardware problem (caused due to bad of VRAM installed on ur graphics card): Remove ur graphics card from expansion slot (PCI-E/AGP)and then plug monitor data cable to normal serial port available in the motherboard (Resides back side of ur system).
Thanx
Gimme ur acknowledge by rating me.
Romy Decostza
Dec 24, 2008 | Abit KN8 SLi Motherboard
Abit kn8 sli motherboard won t boot up
PULL OUT THE WIRE FOR A POWER SWITCH ON THE BOARD AND TRY TO SHORT BOTH PINS WITH A SCREWDRIVER
Oct 17, 2008 | Abit KN8 SLi Motherboard
Problems with pci-e video card.
Try reinstalling the PCI-E drivers or AGP drivers (if you are using that interface) from your motherboard cd and see if there are any problems with that. Check device manage under system to see if there are any red x or yellow flags next to any hardware devices.
Jul 15, 2008 | Abit KN8 Ultra Motherboard
Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
Jun 30, 2008 | Intel D101GGC Motherboard
Problem with display
Some iiyama's have 2 inputs. One DVI and one analog. Also, some of the older ones used BNC connectors. What I'm getting at is make sure you have the right input selected in the monitor's menu. Hope this helps....JF
Apr 02, 2007 | iiyama S 900MT1 (White) 19" CRT Monitor
Abit KN8 Ultra Motherboard Logo
495 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jose Velazquez
Jose Velazquez
steyr1
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
