Question about Teac AG-680 Receiver
Remote trouble videio/aux, muting,power & volume stopped working.sometimes you get lucky & one may work after pressing,holding,smashing,shaking time after time,except the power. its about 5 yrs. old. changed batts, took remote apart, cleaned it, nothing. whats up?
Did you clean the contacts between the rubber remote buttons and the wafer board below it? Rubbing alcohol works best. Sometimes when enough dirt gets in, it gets harder to work. If you HAVE cleaned that, I got nothing for you... Get a video camera and see if it is sending a signal at all, and determine that the problem is with the remote and not the IR receiver.
Posted on Dec 17, 2007
SOURCE:
My remote won't change from AUX to Tv and all of the buttons don't work on AUX except for the volume and mute, how do I get it back on tv? Thank you
Try to push the TV button that is lit red at top middle of remote for 5 seconds in stead of hitting input. In other words by holding the tv button down it might trigger it to respond better. Thanks Mike
Apr 07, 2013 | Televison & Video
I can't find a code for my BOSE Solo on the Dish network Hopper remote. Can anyone help?
Don't go and search for IR codes as you'll waste your time. Use the learning method. Take your bose remote and put it on a flat surface and point it toward the little square receiver on the dish remote (located on the top left side). Then press the "aux" mode button on the dish remote until all the mode buttons light up and the aux mode light starts to blink. Then press the record button on the dish remote for 3 seconds until the aux mode button lights up and stays lit (it then stays lit during the whole learning program). On the dish remote press the button you want to learn but don't hold it down (I started with the up volume) . Then press the corresponding button on the bose remote but hold that down until the aux mode button blinks once and comes back on (if the mode button blinks three times the dish remote did not learn the command and you should try changing the batteries on the dish remote if it happens repeatedly that it fails to learn). Program the remaining commands by repeating the process of pressing a button on the remote, then pressing and holding the corresponding button on the bose remote. Don't be afraid to do it with the mute and the power buttons too. During this process if you don't press a button for more than 30 seconds it will time out and nothing will be recorded and you will need to start again. To end the programming press the aux mode button. When you are using the bose solo using the dish remote you just need to remember to press the aux mode button first so it flips to command the bose solo.
Dec 30, 2012 | DISH Network IR Remote Control
Yamaha yas-101 uverse codes
I had the same problem with my U-verse s10-10 remote and a yamaha SR 300 soundbar. Here is how I got my volume control (but NOT power control) on the yamaha working:
First - always send volume control to the AUX button:
Press and hold AT&T key and OK for 1 second, release, look for 2 flashes.
Now press AUX button. The AUX button will show a long flash.
Second - Go through the manual programing steps listed in the guide for the AUX button (hold AUX and OK for 1 second, release; 2 flashes, punch in code). But instead of pressing the Power button to try to turn off your yamaha soundbar, press the volume up / down and Mute button. I think the code that worked for me was 4045 but I honestly don't remember.
The key is that you have to send the volume control to the AUX button first or it's all a wash.
Jun 26, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
I want to control my Sony DAV-HDX576WF with my Comcast remote control and need the remote control code.
Reposting from multiple sources.
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TVicon1.png/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951Power = 32719Mute = 33743
Good luck. Let me know if it works.
Also, to program your remote to function volume controls while in CBL or TV mode without switching between modes to change the volume, see below. Source http://www.hifi-remote.com/forums/viewtopic.php?t=8831Quote:Locking Volume Control To TV or AUX Mode:
1. Press and hold SETUP until the Red light flashes twice, then release SETUP.
2. Enter 9 - 9 - 3 (Red light will flash twice).
3. Press and release either TV or AUX (Red light for selected device will flash twice).
Jan 29, 2012 | Sony BRAVIA® DAV-HDX576WF Theater System...
We have to hold the remote control button hard and straight at the reciever for ti to work
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
May 20, 2010 | Yamaha HTR-5860 Receiver
Tv code
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try the volume and power button to tset the code
  • 2 possible codes for Element TV, 10835 and 10178.
    If that doesn't work, you can try searching through all the codes stored in the remote. Here's how you do it:
    • Set the "Mode Switch" to the desired mode such as TV for a Television.
    • Enter the code "991" followed by the "device number"
      1. for Televisions
      2. for "AUX 1" devices - VCRs or DVDs
      3. for "AUX 2" devices - Audio
    • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
    • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
    • When you've found the setup code that works for your device, press the "Select" key.
    May 28, 2009 | Televison & Video
    I'm looking for the remote code to program a directv remote to a Polariod model ttm-2410 tv. Know any?
    direct tv gives this code 11641
    Setup Instructions
  • more possible codes 11326 11991 10765 12002 11992
    still more
    11523 11276 11498 11327 11328
    11314 11262 11962 10865 11316
    11286 11341 10178 10835*
    Codeslisted with an asterisk (*) are possible alternate codes for yourdevice. These alternate codes should operate the primary functions ofyour device in most cases (Power, Volume Up/Down, Mute).
    There is no other setup code indicated for your product
    that links to the model number you entered.
    Youmay still find a setup code that works for your device by steppingthrough the library codes in your remote. The following instructionswill help you do this. StepNSet
      1. for Televisions
    • You can step through the setup codes for this mode by pressing the"Channel Up" key to go forward through the codes or pressing the"Channel Down" key to go back to the previous codes.
    This is all the information I could find, Poraroid does not offer a URC code.
    Hope this helps
    Please take the time to rate this solution
    Feb 01, 2009 | Televison & Video
    How do I stop the menu loop?
    press mute on the remote once and then press and hold mute and menue at same time.
    An S' will appear on screen.
    now you are in the service menue
    press key number 9 on your remote this will perform a self Diagnostics
    if this dosent work
    press and hold volum on front of tv set then press 9 onthe remote.
    power set off then on
    youe should be reset.
    Jan 13, 2009 | Toshiba 27D46 27" TV
    Need remote code for 22lv505 for dish network
    Your code is 750....... Program the remote control in TV mode and then in VCR **repeating the steps** (or AUX - press 1 before entering the DVD code) mode.
    How to program your dish network remote for your tv:
    1. Use the device’s buttons or its remote control to turn on thedevice.
    2. Press and hold the mode button for the device you want the remote to control, for about three seconds. When all the other mode buttons light up, let go of the mode button - that mode button should now be flashing. For example, hold the TV mode button for a TV until all of the other mode buttons light. When you let go, the TV mode light will flash.
    3. Only for the AUX mode, Use a number button to enter 1 for a second VCR or DVD player
    4. Use the number buttons to enter one of the device codes that I have given you.
    5. Only for Limited Mode, Press 1.
    Limited Mode- allow you to only use the remote to Power, Mute, and adjust Volume on your tv.
    You cannot change the tv channel when the remote is in limited mode. You can only power on your
    VCR in limited mode
    ****Note: Skip this step if you do not want to use Limited Mode.****
    ________________________________________________________________
    6. Press the POUND (#) button. If you entered the code correctly, the mode button flashes three times.
    7. Press the blank POWER button to test if the code works for the device. If it does, the device should turn off.
    8. Turn the device back on and try some other buttons to make sure they work. Sometimes, the blank POWER button works when other buttons don’t. If the code works for other buttons
    ** Stop Here**
    Let me know if this helps..
    1388f48.jpg If I have helped you, dont forget to rate!!!
    Jan 03, 2009 | Toshiba 22LV505 22 in. LCD TV
    What remote control code does the Onkyo TX-SR304 use?
    1) Tap AUX
    2) Press & Hold Setup (1 then 2 blinks)
    3) Enter 30842 or 0842 (The remote should blink twice)
    4) Press & Hold Setup (1 then 2 blinks)
    5) Enter 994 (2 blinks)
    6) Tap Setup (1 blink)
    7) Enter "00051" (1 blink per number)
    8) Tap Power (not All On, just "power") (The remote should blink twice)
    9) Tap AUX
    10) Press & Hold Setup (1 then 2 blinks)
    11) Enter 30135 or 0135
    Aug 27, 2008 | Onkyo TX-SR304 Receiver
    Teac AG-680 Receiver Logo
    150 people viewed this question
    Top Teac Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Marvin
    Marvin
    Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
