Question about JVC KD-NX5000 Car Video Player
Bad navigaion after the system is done calibrating the arrow head shows where i am but it starts moving backward and in a few minutes it is far away why is this doing hat and what can i do to fix it
    Problem Solver:
  • 17 Answers
If its moving backward, then you need to set the correct "Reverse Polarization" settings. The system thinks you are in Reverse. Did you hook up the reverse / back-up wire and correctly set the Reverse Polarization?
Posted on May 30, 2008
    Champion:
  • 227 Answers
Try to mount the gps antenna on the roof or front mirror where 2 to 3 satellite can hit it at once. Goodluck.
Posted on Mar 07, 2008
My device routes me to major highways miles away to get to the destination even if I am only a few feet away
You are probably trying to navigate in car mode instead of off road. make sure you have they type of navigaion correct
Aug 05, 2014 | Garmin GPSMAP 60CSx
Colour Laserjet 2600n has problem shown in its manual as "Vertical streaks or bands appear on the page" and the remedy is "Replace any low print cartridges". A printout of Supplies...
Try removing each of the cartridges and vigorously shake. It is possible that the powder inside has formed into blocks, partially solidified, gummed together. This is specially true if the ambient temperature is usually cold and the printer is seldom used.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 31, 2008 | HP Office Equipment & Supplies
I hav3e a Whistler 1765 unit and when I tried to transfer it to a new car it would not calibrate, even after 5 tries. It was "stuck" on 315 degrees. Then the display changed and was stuck on...
There could be few reasons for this.
1. There is strong magnetic field near the radar detector. This could be even car speakers.
2. There is power lines going above the place where you are trying to calibrate.
3. To complete calibration you need to press both the volume control buttons while the vehicle is parked.. The display will show "CAL MODE". Then slowly drive at least 2 complete circles while in calibration mode. Then again press both the volume control buttons for 2 seconds until it beeps and shows " CAL DONE" in the display.
Sep 03, 2011 | Whistler Vehicle Parts & Accessories
My HP CM1312nfi laserjet has started to print a shadow behind all color text and images. The same day this started, the printer kept going into cooling mode as I attempted to finish a print job. I moved...
According to your problem first clean the toner cartridge by dry cotton carefully. May be the toner is almost finished or get damp few toner of the cartridge. Refill the toner cartridge. Then install the cartridge properly and reboot it. It will solve your problem.
Jul 25, 2011 | Office Equipment & Supplies
The wiper blade is stuck to the print head of my xerox c2424 printer. how do you take the ink cartridge tray out to get to the print head. i have it torn down that far...bonnie
The printhead and wiper could be heated to soften the ink.
Enter Diagnostics by holding the back arrow and "i" button while powering up. Go to the Monitor menu and turn on "All Heaters"
After a few minutes, it should be able to be moved away.
This situation may have broken 2 Camshafts and perhaps even motors. If you continue to get an error 07,010 then buy this kit "C2424-Z2" It may require a technician to install.
Whit
Item, Inc.
Oct 01, 2010 | Xerox C2424 Copier
The Black prints faint on the left side of the page for our HP2605dn printer.
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
Jun 08, 2010 | HP LaserJet 2605DTN Color Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
4. Cleaning Problem
May 17, 2010 | HP LaserJet 2605dn Printer
Hp laserjet 2660n prints every page on red background even from auto testing; I have just bought it.
This is a common problem with this printer. Try this and it must be done 3 times in a row. Also, sometimes if there cartridges are not all from the same maker there may be issues. The transfer belt can be changed but it requires removing a few covers.
Calibrate the printer at the control panel of the printer
  1. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads System setup and then press c00314544.gif (SELECT).
  2. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads Print quality and then press c00314544.gif (SELECT).
  3. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads Calibrate color and then press c00314544.gif (SELECT).
  4. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads Calibrate now and then press c00314544.gif (SELECT).
  5. Press the c00314544.gif (SELECT) button to confirm Calibrate now.
Aug 04, 2008 | HP Color LaserJet 2600n Printer
Pen writes in one spot, but image shows up 1/2 below.....
1. To calibrate the ENTouch 1000 power off the device.
2. Prior to restoring power touch the pen to the center of the screen and do not move it.
3. Power on the device. Leave pen in center of the screen and do not move it. If you move it the device will not enter calibration mode.
4. Allow device to boot. If you held the pen in place the EnTouch 1000 will enter calibration mode.
5. Follow the on screen instructions. Be very methodical and do not try to rush it...
Nov 20, 2007 | Ingenico eN-Touch 1000 Digital Pen
The aroow head keeps moving
check your reverse wire siginal. Make sure you have the correct polarity selected.
Oct 29, 2007 | JVC KD-NX5000 Car Video Player
JVC KD-NX5000 Car Video Player Logo
326 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
