Question about Sony Handycam DCR-HC42E Mini DV Digital Camcorder
Sony DCR-HC32 display problem
i have a sony DCR-HC32 miniDV camcorder. After 1 yr warrenty expired, the LCD display started to change colours like complete green, red and then finally blocked out. I used the view finder for a week. then it also started to give overexposed image and under exposed view. But all the time, it record good picture as usual. It is expensive to take it to sony or other places (>60% of its purchase price). I found some help from your website. it ask to change the flex cable. Please give me the exact name and part NO of cable. How easy it is to fix?
thank you
  • 217 Answers
Replace the flexwire asap, it's hard to fix and you need pro help to do it. flexwire has a possibility of shortcircuiting the unit, the reason your small viewer started to show problem. Here in the philippines i'm not replacing it with an exact replacement, instead i'm replacing it with the more strong wires or cables such as the one used in laptop computers, still, you need profix to do it. [:0)
Posted on Oct 29, 2007
I cannot connect the sony camcorder dcr-hc32 to the computer because I cannot find the usb driver.
You can download required driver from Sony Support, click that link and download required driver as per Windows running in computer.
Mar 26, 2011 | Sony Handycam DCR-HC32 Mini DV Digital...
Problem with the Sony Handycam DCR-HC32 Mini DV Digital Camcorder Moisture condensation turn off 1 hour
It can be a tiny dew switch mounted on near the drum motor, Which you can change off values with a resisitor for the fault .
Also if you can blow hot air into the cassette tray this would enable the dew switch to open out.
Sep 28, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
SONY HC32 - LCD panel not working when pressing icons. Also, when it does work, the incorrect functions appear for the menu selected
I had similar trouble on my 2nd hand HC32 - turned out to be faulty flex cable that runs between LCD and the main body.
Cost me around 60 USD to fix by non-SONY service shop.Now it works like new.Worth every dime for this outdated camcorder.
Jul 22, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
I have the same problem with a DCR-HC45.The culprit is the ribbon between the circuit board and the LCD display,but my problem is worse,sometimes the screen turns white and I can't see anything on it.I have no idea from where to buy a replacement ribbon but I know how to replace it.
Jun 23, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
Focus issues
My reply is bit technical. Your camera requires Flang-Back Adjustment.
Above said adjustment will set focus lenses in correct order / position to obtain crispy focus as it was before.
There are few special tools designed by Sony used in Flang-Back adjustment and only Sony Service Centers can perform such adjustments. Non-Sony repair shops do not have such things.
Just for reference, below view shows required tools for adjustments in this model.
Need further info let me know please.
Nov 27, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Board dcr-hc 32
dear sir
good evening,
i have bought the sony handycam DCR-HC32. cam is working in order. but there is some problems. that the red colour on LCD is off. what is the reson.
pl explain the fault & repair reson.
Sep 15, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Display on camera is all red and black with static
call sony support there is a know problem with the cable to the lcd
Feb 26, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
LCD problem
the flex wire of the lcd monitor is already cut ...go the service center for replacement of the flex wire...or to the other service center for fixing the flex is to difficult to fix the wire if you are not a technician cause that wire is like a strand of hair....
Sony Handycam DCR-HC42E Mini DV Digital Camcorder Logo
269 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
