Question about Philips 32PF5320A 32 in. LCD Television
LONG BLACK MARKS
I HAVE GOT BLACK MARKS ON THE TOP LEFT HAND CORNER OF MY PHILLIPS LCD  TV, THEY ARE VERY PROMINENT WHEN THE BACKGROUND IS WHITE. THE BEST WAY TO DESCRIBE THEM THEY LOOK LIKE DARK CLOUDS AND HAVE APPEARED WITHIN THE LAST WEEK.THE TV IS AROUND 20 MONTHS OLD.
I HAVE TRIED TO RE SCAN THE TUNER BUT TO NO AVAIL.
CAN ANYONE HELP ME AS THE ONLY THING I KNOW ABOUT TV'S IS HOW TO CHANGE CHANNELS!!!!!!!!!!!!!!!!!!!!!!
THANKS,
JL.
  • 2 more comments
  • Anonymous Nov 25, 2007
    have exactly the same issue. Have tried various things including unplugging for 1/2 hour but still the same.
    Any ideas anyone ??
  • dave51 Dec 28, 2007
    I've got the same problem but it is down the lefthand side of the screen. It looks like a stain.
  • Anonymous Oct 30, 2008
    i have a samsung 40" lcd it looks like black clouds top to bottom makes peoples faces look very tanned worse on a dark back grouned
  • Anonymous Feb 18, 2009
    I have the same issue, only with a westinghouse
Try firmly rubbing them out with a non-lint cloth.
Posted on Jun 03, 2008
Canadian company Tim Horton's uses SHARP 37" LCDs in the stores for advertisements. Alot of them have what look like marks from improper cleaning or almost cloud like stains on the sides of the screens.
On the Sharp screens this is panel separation and is a sign that it is time to replace the screen. This should be covered if the screen is still under warranty.
Posted on Apr 28, 2009
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Sharp tv has small black and white image in black and white and half screen pink
Sounds like your LCD Control board went bad. Very small chance it is your main board since you said you cant bring up a menu.
Apr 11, 2012 | Sharp Televison & Video
On my sony bravia tv if i use bt vision box hdmi 1 is displayed in left hand corner of tv screen how do i turn this display off
On the remote control on the top left corner a button marked i+ is there. Press it. This will eliminate the hdmi sign.
Oct 27, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
A black _ in the upper left hand corner (size of underscore)
It is what we call a "Shatted Pixel" and you can fix it by flashing your screen
Dec 22, 2009 | Dell Computers & Internet
I have a sony kf-42sx3oou, i have just had the lamp replaced, since replacing it a few blue spots appeared in the top right corner but today a yellow line has appeared on bottom left hand corner, could you...
This problem was probably there before, but you only noticed with the new "Brighter" bulb.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty. If out of warranty, I suggest living with it or selling it if out of warranty. Turn down the Brightness and it will not be as noticeable. I am sure you only see this with bright images.....like white backgrounds and such
Good luck.....
Mar 04, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Maxent 27" LCD Flat Screen TV
This is a fault i have seen with phillips lcd tv's and i suspect it could be the lcd screen itself,the ribbon cables from the screen are heat contacted on to a circuit board and there could be anything from 10 to 15 of these ribon cables and over a period of time the heat generated from the internal panels will deteriorate the plastic ribbon cables.
Try twisting the screen gently by placing your left hand on the top left hand corner and your right hand on the top right hand corner and gently twisting,if the lines go and then come back after you let go then a new screen will be required but it may be cheaper to buy a new one,could be worth buying the extended warrenty.
Feb 02, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Philips 32PF5320A 32 in. LCD Television Logo
654 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
