When I plug in the cord nothing comes up to allow me to transfer any photographs I have taken onto the computer and in a folder. The wire gets very hot also, but this problem never occured when I first bought the digital camera. I do not have Genuine Windows, do you think this could be the problem? Or that pehaps the software just got delted. This problem also happened with my MP# player, but when I had someone go on and figure out the problem he told me that I needed to register it online, but I can not find out how to get the software.
You may have to change the chord (USB cable) you are using presently. When you connect your device windows notifies you that a new hardware have been found. If the driver is not installed, the system will request that you insert the disk that came with your device. As soon as you do this, the hardware wizard will take up from there.
If you don,t still succeed, open up my computer and right-click aon the device and click DELETE.
Then shutdown your system. Ataach your device again and boot the system and follow the reinstall instructions that follow.
Good Luck.
Since you do not have "Genuine Windows", I cannot comment on any software issues.
The part that really concerns me is "The wire gets very hot also".
USB is really low voltage. It sounds like you have a broken USB interface that is looping the current.
Your cord is getting hot most probably due to high voltage or a shot circuit in your device or cord....
Most of the USB device are not at all any problem. Your Software for your device may be corrupted of any file is missing.. Just reinstall the application and try once again if it still dont work i would recomend to formate your windows drive and then install it it will surly help u.
if you dont have a cd for the installation just downloade it from the company official website..
If the wire is very hot check the voltage of your outlet use the plug of ur cam.Regarding from the transfering of file from camera u need to install the cd of ur cam to ur pc.If u dont have a cd what u need to is to download.look for the brand of ur cam go on the website it belong.Example sony..search for the official website of this.If ur are in the portal look the word support click it and click the word driver download.Then type the model of ur cam then follow procedure.
Does the camera register that it is connected to the computer? Does the computer show that it is connected to the camera in My Computer?
