check your connections to make sure they're tight, first. if the balance knob makes a crackling sound while trying to change from one side to the other, the guts are dirty and need cleaned.
Was this helpful?
Yes
No
Popular Solutions for Sony MHC-GX250 CD Shelf System
At low volume the Right Channel Speaker cuts in and out. When i turn the volume up it stops. Ive...
(More)
At low volume the Right Channel Speaker cuts in and out. When i turn the volume up it stops. Ive check wires and they are fine.
I got this system off Ebay. It is the MHC-GX250. It played fine for about an hour. I put a CD in and...
(More)
I got this system off Ebay. It is the MHC-GX250. It played fine for about an hour. I put a CD in and it played for a few minutes, then something popped and it quit. Now it just grinds and have a problem with the drawer opening also. Everything else was playing ok, then after shutting it off and turning it back on, all I get is the Standby flashing on the display. I can unplug the unit, plug it back in and the system will turn on. But it will not turn on again after shutting it off. It goes back into Standby. I have tried the reset operation, but that does nothing. Need some help. thanks
I get nothing on AM...FM works fine and so does everything else. It used to work, now nothing...any...
(More)
I get nothing on AM...FM works fine and so does everything else. It used to work, now nothing...any idea what to look for/fix, etc?
