Forgot my login password for my wireless router & cannot figure out how to reset it. Help, I am not computer saavy!!!
SOURCE: WNDR3300 RangeMax Wireless N Router.
i did download the sofware of the ARES ULTRA and cann,t connecting to the internet
SOURCE: cannot login and have reset....
if you want to access the modem
lynksys password
username: admin
password: admin
not admin for username: and 1234 of password
the default security is,, admin, admin
thanks
SOURCE: I have a netgear router WGR614v9 . I forgot its
There should be a reset button at the back of your Netgear router. Press it for 10-30 seconds and that should reset it back to factory settings.
Cheers!
Angel
SOURCE: how do i hard reset
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device! See the following articles for more information: hope this helps
SOURCE: I can't geto into router's
I don't know what the URL you gave is for. You access your router from your web browser (Firefox, IE, etc.) with address http://192.168.0.1 or //192.168.1.1 (depending on the model) from a computer connected to one of the router's wired ports. Unless you have changed them, the default username is admin and the password is password for most Netgear routers. A few models use a capital P in password, and some use 1234 as the password. But "admin" and "password" are most common.
Even if you can access the router, I'm not sure you'll be able to read your wireless security key. I don't think the Netgear routers display the key in plain text, but I may be wrong. It's been a while since I've set one up and I don't have one handy to check. If it does show plain text you're home free. Otherwise, the thing to do is reset the router by pressing the recessed RESET button on the rear panel, holding it for about 10 seconds and releasing it. The router will restart and all its settings will be back to factory defaults. This includes the router username and password, so if you can't access the router setup pages because you don't know them, this will solve that problem.
Once you've reset the router you can set up your wireless network again, and enter a new security key. This time write it down somewhere so you don't go through this again. I put a text file with all their information in it on machines I set up for people, then give it a name and extension (netstat.sys, for example) that doesn't make it obvious what the file is, but the customer knows where to look if they need it.
