I've changed the bulbs. Sometimes the lights come on for a second or two then back off?
You should have a fuse in the fusebox for the instrument cluster. The instrument cluster houses your gauges, speedometer, clock, and temperature gauge or light. Check the fuse to see if it blown and replace with the same size number on the fuse. Don't decrease or increase the number of the fuse. Stay with the same amp number that is on the old fuse when you replace it. Hope this helps.Good luck.
SOURCE: electrical fault on peugeot 406 hdi
lift the carpet at o/s/f {drivers front footwell} there is two multiblock connecters guarenteed tobe sodden with water disconnect connectors& dry with a hair dryer on low setting hopefully the pins are not corroded reconnect connectors this is aknown fault i have worked with peugeot&citroen for 24 years kind regards alastair
SOURCE: speedo not working on renault kangoo 1999 still
If its still clocking up the miles then the speedo its self is faulty,Fit new ometer.Not senser.Good luck
SOURCE: 1995 chevy suburban headlights won't come on
Common for the wire harness on the switch to go bad. Inspect the wire harness where it clips on to the switch and look for any signs of damage.
The plastic heats up from the current running through the switch and causes it to melt and then you loose connection caused from melted plastic between the contacts from the harness to the switch.
There is a upgrade to the headlight harness which is larger then the ones that came with the Suburban to address this issues. You can get them at the dealer or NAPA i believe.
Good luck and keep us posted. Thank you for using fixya and stay safe.
Molson02536
Testimonial: "I replaced the turn signal switch which solved the problem. It was that. The headlight wires had melted at the connector. The pain is the new turn signal switch has a malfunctioning wiper component causing the wiper delay to turn on with out being on. Now I have to do it all over. "
dont think it can be a fuse as the lights sometimes come on for a moment then go off again, seems to be when braking?
