My Tv Has A Blue Double image ive tried changing color in menu but it has no effect, its a problem in the screen right?
SOURCE: Blue Screen
Try re-starting your pc and tapping the F8 while it starts up and try getting in through "Safe Mode". If you can get in click "Start", "Run" and type "cmd". Hit OK. At the dos promt type "sfc" and let windows check your files.
SOURCE: Connecting Toshiba notebook to Samsung LCD TV - small image only
because you have added a new monitor, you have to go into your graphics settings and set the screen resoloution to a setting your comfortable with
hope this helps
regards
SOURCE: My laptop screen started to look like an old tv
This definately is hardware issue.
2 options for you.
1. open the screen and check if the signal cable to lose. if you can out it in right place you can fix this onyour own.( I would recommend this only if you have prior experience in troubleshooting laptop hardware)
2. otherwise see the hardware vendor.
SOURCE: might have been dropped, paart of the screen stays
yeah its taken a pretty good hit, the screen has a broken ink cartrige, and the touch pad for the mouse has probably come unpluged from the mother board
SOURCE: Screen is black, shows no
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this will help...Your response is very much appreciated...
