Question about Dell A940 All-In-One InkJet Printer
ERROR NO. 0502
Was putting in a new black cartridge......and when I shut the lid....got this error?  says "no black cartridge"  hardware error 0502...any thoughts?
tried to open up and re-install the black cartridge but the toners are way over the the left and won't let me move them back to the center where I can work with them.
  • 7 more comments
  • Anonymous Nov 08, 2007
    i put a new black cartridge in and i tried to print, it printed a little bit and then it said hardware error 0502.
  • me jane Nov 30, 2007
    when i use my A940 printer, paper runs through and prints nothing. Then I get tje error 502
  • Anonymous Dec 16, 2007
    Printer stops, paper is spat out and window on computor says there is an error, turn off printer, open lid, check cartridges are not jammed, restart and carry on, this works for a short while, then it happens again, envariably halfway through printing a photo or my CV!!!!!!
    Regards
    Terry
  • shirleydee Feb 24, 2008
    Hi, my dell A940 has hardware error 0502, I have tried cleaning everything there, but the cartridges are firmly stuck right on the left side and I can't get them to move, any help would be great, I am about to "drag and drop" it over the balcony.........shirley
  • Rece Mar 21, 2008
    Dell A940, all in one- Similar problem, as soon as I turn the printer on it shows the Hardware error 0502. The cartridges are stuck on the left hand side and will not move. Any ideas on how to clear the error message?? Thanks
  • Anonymous May 30, 2008
    What can i do; not working the cartridges slam against the sides of the printer
  • bjjessee Nov 30, 2008
    I have the exact same problem
  • antoun_m Jan 11, 2009
    Alot of ppl say E:502 is a common error and its easily solved by cleaning ur rod inside ur printer in which the cartridges run upon.
    i cleaned the rod with a E40 liquid and Kleenex as some on suggested but it didnt work .... any other solutions i shud try?
  • Anonymous Feb 27, 2009
    cartridges stuck on left side error 0502
    Genius:
  • 1,601 Answers
Thecartriges run on a steel shaft and respond to resistence. Take a kleenex and clean th shaft. Then lubricate it with WD40 or some other lubricant. The 0502 error will go away. The Clay Works georgepcd@comcast.net
Posted on Jan 19, 2008
The cleaning of the bar did the trick, thanks guys
Posted on Nov 23, 2009
Wipe the silver bar down w/alcohol! It worked for me; slides just like it is supposed to. It was icky! Also, when the printer doesn't detect the cartridge, it maybe the cartridge is defective, even if it is new. I had that w/my lexmark, which is much the same. I checked it w/an old cartridge & it did acknowledge it. So, another trip to Walmart, & it was all good. Just a bad cartridge....
Posted on Mar 04, 2009
I tried "cleaning the ink cartridge nozzles". Press Options until Cartridges displays > Press + until Clean displays> Press Select. I had to do it twice. Then I took a soft wet rag and ran it across the metal bar that the cartridges slide on. So far it has worked.
Posted on Aug 31, 2008
Sir,
I am using Dell AIO Printer A940 for one year.Its show best
performance.but two days above printer show on screen (HARDWARE ERROR:0502).and computer no detect printer.
when I press power batton printer on and show error:0502.when i open the cover cortridges not moves.but when i shut the cover cartridge is not move.
please Resolve this problem.
Thank you.
service tage:htsnj21
express service code:38806945849
E-mail:starlight_200046yahoo.com
Posted on Apr 05, 2008
Error is Cartridge stall, hardware error 0502. Help?
Check this article on how to resolve a Hardware Error 0502 on LCD Display: http://bit.ly/UVCOPu
If it doesn't help, you would need to purchase a new printer.
Nov 19, 2012 | Lexmark X6100 Flatbed Scanner
Receiving message Error 0502
hello
this should help
Lexmark printers with "Hardware Error 0502? Published on February 11, 2006 in hardware. 252 Comments Tags: 0502, error, fix, hardware, lexmark, printer. Good tip for the Lexmark All-in-one inkjet printer owners (mine is the X6170):
98393867_e286ea59ca_t.jpgAfter some months of use, your printer might get the habit of stopping in the middle of a page and showing "Hardware Error 0502" on the LCD display. If you leave the printer alone for a while, it might start printing again. Then again, it might not. Pretty annoying.
The Lexmark support site will let you power off, remove the power cord for 30 seconds (!!), take out the cartridges and fiddle with some encoder strip. This whole procedure might take you up to 30 minutes and it will not help (been there, done that).
The real answer is given by a person called 'clem':
98393885_c4f82c99a9_m.jpgHardware Error: 0502.
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
Clem
(from fixyourownprinter.com)
This works! Clean the ****** with a paper towel (another page talks about re-lubricating the thing, but that was not necessary in my case). The towel will be black (ink residu, presumably), but there you go printing to your heart's desire again
Nov 30, 2010 | Office Equipment & Supplies
Printer displays hardware error 0502 wont print " HELP "
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
.... most of the time, it's the encoder strip that is giving the problem..
goto
http://support.lexmark.com/index?userlocale=EN_US&locale=EN&page=content&segment=SUPPORT&productCode=LEXMARK_X5150&id=HO2707
May 24, 2010 | Lexmark X5150 All-In-One InkJet Printer
Error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
My dell A960 printer has hardware error 0502.How
Dell A960 All-In-One InkJet Printer
Error 0502 and 0504
Hi there
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Dell A960 All-In-One InkJet Printer
Replaced black cartridge, color fine, but keep getting notice "hardware error 0502"
Hardware Error 0502
Hello there
Ok it is.
And maybe put a little bit of oil on it with a cloth not too much.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Feb 07, 2010 | Lexmark X6170 All-In-One InkJet Printer
Getting hardware error 0502
Hardware Error: 0502. On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
send you the link where you can figured out
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
sourav
Jan 05, 2010 | Lexmark X6170 All-In-One InkJet Printer
How do I correct error 0502 hardware error?
There is a very good walkthrough on resolving these issues:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:133:0:0&framed=&docid=ENUS22800&relevance=1
Oct 05, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printing error says: Hardware error 0502 (?)
he real answer is given by a person called ‘clem’: 98393885_c4f82c99a9_m.jpgHardware Error: 0502.
Clem
This works! Clean the ****** with a paper towel (another page talks about re-lubricating the thing, but that was not necessary in my case). The towel will be black (ink residu, presumably), but there you go printing to your heart’s desire again.
Jul 12, 2009 | Lexmark X5150 All-In-One InkJet Printer
Dell Printer A940 Hardware error
Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
Figure 1: Open Ink Cartridge Lids
Back to Top
» Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
    new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press Select.
new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
Back to Top
» Reposition the Encoder Strip
  1. Remove the power cord from the printer.
  2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
  4. Gently move the top part of the printer belt to the right.
  5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    Figure 1: Inkjet Printer Encoder Strip
  6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
  7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
  8. Once the encoder strip has been re-seated, close the scanner lid.
  9. Re-connect the power cord to the printer.
Jul 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
1,193 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
