Question about IOGear GPSU21 Print Server
Print server software stops at select a printer
H6000 laptop, wirerless connection
Qwest advncd netwrkg modem QW2701KITV,
HP6210 Officejet all in one printer.
Installation programs stops at select a printer?
Printer works ok when connected directly to laptop.
    President:
  • 2,923 Answers
The GPSU21 is designed to work with standard printers only. You may refer to the printer's compatibility list for more information.
Posted on Apr 14, 2009
Did you verify that the HP6210 is supported?
Posted on Mar 14, 2008
What do I need to make my printer wireless?
You need 1) a wireless router with a USB port that supports the HP OfficeJet printer. 2) The software for your router to run a printer on the USB port. Obviously, you will need a USB A/B male end cable.Note: the scan features of the all-in-one may not work unless the printer is directly connected to the computer. Bi-directional communication is required for scanning and the router software may not support this completely.
Check the list of supported printers closely for older routers. I have a Cisco Linksys E4200 v.2. This router supports all the HP printers that I use.
If this is a new installation of the printer, first install the printer on the computer. If you have Windows 7, just connect the printer to the USB port on the laptop. This will install the OS drivers for the printer. (For Windows XP, go to the HP site and get the full software.)
Next install the wireless router between your modem and computer and set that up. (If you have DHCP (dynamic address allocation), it should be automatic. Otherwise follow the directions.) Next install the router software (for my router, it was Cisco Connect).
My next step was to launch the Cisco Connect program and connect the printer directly to the USB port on the router. In Cisco Connect, choose add a printer and find the printer connected to the router. Print a test page. (At times, I've had to reset the port that the printer is on in the Windows Control Panel Printer Properties. (For the Cisco Connect, the printer is on the DOT4 port.)
Other routers will be set up somewhat differently.
Another option is to have the printer connected to a desktop and then make it a shared printer with the wireless router communicating between the laptop and the desktop. This makes the desktop the print server, so it needs to be on when you want to print. If you have several computers with Windows, this can fairly easy to set up. Make sure that the computers are in the same Workgroup (XP) or Homegroup (Win7). Enable sharing and you are done.
I hope this helps.
(who has a OJ 7000 (with ethernet port) and a LJ1320 (USB) connected to the router. Three computers talk to these printers with the laptop on the wireless network. On an older router that didn't support the printers, the laptop was the server for a previous OfficeJet and one of the desktops was the server for the LaserJet.)
Aug 27, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Will the hp6210 print using a wireless connection?
There are no wireless card installed in that printer just USB connection and PictBridge connection (check this link for specifications http://www.cipa.jp/pictbridge/contents_e/01pictbridge1_1_e.html)
Sep 23, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have a HP OfficeJet K60 printer. I have a Linksys WRT54G V8 broadband router. I would like to set up printer so that I can print from my laptop without connecting the print cable to the laptop.
Do you have the jetdirect print server attached to the printer? If so, follow the instructions for the print server setup before connecting to the broadband router
Jun 07, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
Need to install HP6210 software (free). Lost org. disk
Specify your OS:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=421991&lc=en&cc=us&dlc=en&submit.y=4&submit.x=10&lang=en&cc=us
May 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet Pro L7580 Wireless Connection
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I keep getting print spool message about my printer, I just hooked up a new Qwest modem with wireless
I found that you need the newest driver from the HP site and you may need to load it again and have it look for your printer IP address automatically, Mine was a pain at first and every time I have replaced my switch ot network router I have had to "rediscover" the printer as the network seems to ignore it...
Oct 09, 2008 | HP Office Equipment & Supplies
IOGear GPSU21 Print Server Logo
202 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
