I have found that the installed web cams on most units are inferior and a external USB cam has better quality in sound and picture and are very cheap and can be pointed in any direction and even used to copy photos your screen or documents , so if you are a frequent cam user buy your self a USE cam for $50 or less
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If its just shows a black screen you will have to download the software again If it broadcasts OK - you need to configure your cam to the chat program you want to use - add more info to your question
i have in built web cam ,it was working on windo vista,,now i changed my vista...now it is windo xp
but cam is not working it is full black
how can be solved plz
Normal
0
Also send this to your family
and friends so they have their computer setup properly. Web Camera’s have to be
setup on the program they are to be used with.Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
If you see a black screen when broadcasting your webcam: There may not be enough light in the room. If so, illuminate the room appropriately. Your camera may not be functioning properly. Try your camera with the manufacturer's software. The correct camera may not be selected by Yahoo! Messenger. To change your camera source: 1. Click the "Messenger" menu in Yahoo! Messenger and select "Start My Webcam." 2. Click the "Messenger" menu in Yahoo! Messenger and select "Preferences." 3. Click the "Webcam" category. 4. Click the "Camera Source" button. 5. Click the pull-down menu and select the desired camera. 6. Click the "OK" button. If you see a black screen when viewing a friend's webcam: Check the status message at the bottom of your viewer window. If it says "Stopped," the person broadcasting has stopped broadcasting images. Ask the person to resume broadcasting and try viewing again. If the person is in fact broadcasting and you still see a black screen in your viewer, ask them to check their camera and take the webcam compatibility test.
Replace your webcam with approve microsoft product sometimes webcam with out seal or logo of microsoft doesnt work at all. Because it is not compatible to the OS of your pc.
Is this while you are using on-line MSN, Yahoo etc?
