so what had been hapening is that it could die depending if it was the battery that could aftfect with this. 24 volt battery, and can be ridden for up to 45 minutes after battery charging. The charge time recommended for this Razor electric scooter is about 10-12 hours after each use.
Looks like a repair is in order. Do a TV reset (confirm at least physically that the reset button was depressed). Power down, unplug. Let it sit, turn on later. If nothing, good luck with the repair so better take it to a repair center and have it check and let a professional do it for you....
Sometime the computer in car will shut down a circuit when it sees a problem even if it only occure once. You can try to disconnect the battery for at least 2 min so all sys power off (some have capacitors that mantaine a charge for short time). If a battery disconnect does not clear problem you have go to dealer and have them to clear codes and reset you modules and your preferences
another this to try is get a new battery.
mine had the same problem i would try to charge and nothing and it would turn on for about 30 seconds then turn off and i tried putting it on a charger within those 30 seconds but it wouldnt take a charge.
i got a new battery theat had some charge in it and it worked great! alot of the time thats all you need it a new battery
The Samsung YP-F1 has a reset button located under the black Samsung cover plate. It can be gently removed via a finger nail or mini flat blade screwdriver. Once plate is removed a hole labeled reset will be seen. Use something like a paper clip and press in. MP3 will power down/reset. MP3 data is also retained after reset.
