Whirlpool Air Conditioner
Problem for Whirlpool (ACC108PS) Air Conditioner
Freezing up
By petitt52 on Jun 12, 2009
blows out a mist
Solution #1
posted on Jun 12, 2009
Somewhat Helpful)
gdcroft
Rank: Guru
Rating: 89%, 85 votes
I suspect your air filter is clogged with dust. The front inside panel of the air conditioner should be removable. Take it off to get at the filter. The filter for most of these window units looks like a thin piece of foam. Take this out; rinse off all the dust in a sink or outside using a hose, and then reinstall it. Hopefully this will fix your problem.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Air Conditioner
Questions and Unsolved Problems for Whirlpool Air Conditioner
Do you recommend Whirlpool (ACC108PS) Air Conditioner?
Answer
Answer
looking for instructional booklet for admiral airconditioner 7600 but (cool) 4000 btu (heat)
Answer
having trouble with the fan motor spinning. how do i fix?
Answer
Unit says stop on the LCD screen, don't know why can you help?
Answer
mer. It does blow refrigerated air (just doesn't feel like its cold enough), compressor comes on,... (More)
Answer
we recently replaced the thermostat on the ac unit and did not shut off the power in doing so and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
