Question about Whirlpool MH7135XE Microwave Oven
Whirlpool mh7130xez-1 How do i tighten the handle screws,do i have to take the whole door off
  • 100 Answers
When you open the microwave door, on the inside of the door there is a plastic trim around the glass called a choke that is clipped in that needs to be removed to get to the screws for your handle
Posted on Oct 31, 2007
How to replace the door handle on a whirlpool MH2155XPQ micro wave
The screws that hold on the handle are inside the door assembly. Here is the way its done but its not for the average person. On the inside of the door is a plastic frame all the way around the door. It is held in place by plastic tabs. You have to gently pry off that frame with something like a putty knife or small screw driver. If you are not careful you end up breaking off some of the tabs. Once that frame is off you should have access to the 2 screws holding on the handle. Remove screws---replace handle---and push plastic frame back on.
Jun 26, 2015 | Whirlpool MH1150XM Convection/Microwave...
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here :
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Handle replacement
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
This should be a very simple repair that you can easily perform yourself.
If you have any questions, please post back and let me know. You can refer to this illustration, if you like, to assist you as well:
I hope this helps you.
Mar 17, 2010 | Whirlpool GH4155XP Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Handle screw broken
You have to take the trim off the in side of the door around the glass. Be careful, because the glass could fall out. You should be able to open it with a regular flathead screw driver. There is probably 4 screws holding the handle on. I am pretty sure the only way to get the part is through whirlpool.
Jan 26, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave door handle replacement
Solution for GE Spacemaker Ovens (my model is JVM1650BH05)
1- Remove door by lifting it out of hinges. You will need to remove grille first (2 set screws).
2- Carefully pry off the plastic inside door trim. Use a fine knife or putty knife. There are 10 tabs holding the trim from behind. It's OK if you break a tab! Try to pull out as straight as possible.
3- Once the trim is off, remove the 2 visible screws that hold the door handle. NOTE: There are 2 invisible screws so you are not done yet!
4- You now need to remove the metal ring that holds the latches. To do that, grab the metal ring and using your other hand, release each plastic tab one by one (same tabs as above).
5- Once the metal ring is loose, you will see 2 screws. Remove them if they are still there.
6- Position your new handle and attach using the first 2 screws.
7- Reposition the metal ring by re-snapping it in place. Install the other 2 screws.
8- Replace the plastic trim by snapping it back in place
9- Reinstall door and grille. Tell wife or hubby that you are a genius!
Bonus: use metal washers when screwing down the 2 first screws.
Mar 10, 2008 | Microwave Ovens
The door part# is 4359542 if you need the part number. If you need to know how to replace the door check up by the upper hinge on the inside of the door should be a plastic piece that you can remove so if you lift the door off of its hinges. You may or may not need to remove the grill above the door to raise the door high enough
Oct 31, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool Microwave Model MH7130XEZ-2
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa:
Oct 14, 2007 | Whirlpool MH7135XE Microwave Oven
Bottom screw on handle loose
All my micros had the screw go through the handle into the need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Whirlpool MH7135XE Microwave Oven Logo
272 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
