D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
Jimmy Winkles Posted on Mar 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DI-624 is is not in device managers list of network adapters
Mike M
Level 3:
  • D-Link Master 3,349 Answers
  • Posted on Mar 06, 2014
 Mike M
D-Link Master
Level 3:
Answers
3349
Questions
0
Helped
685870
Points
16707
Routers will not show up in Device Manager. Because there is no direct connection to the router since it's management is done via a web based interface, it is not part of your computer's hardware.
5 Related Answers
Anonymous
  • 123 Answers
  • Posted on Feb 16, 2006
SOURCE: WEP Encryption
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
Anonymous
  • 123 Answers
Anonymous
  • 239 Answers
  • Posted on Dec 24, 2007
SOURCE: D-Link DI-624 wireless router is not working after firmware upgrade try
Try to unplug the router and hold in reset button for 30 seconds see if that works, you probably did that already, But if you can get your computer to respond you should be able to open software Bios. and do your firmware update from there. If not I believe a hard reset is with the router plugged in and holding reset button for 30 seconds, I don't know I sure hope that resets it for you. Thanks take care
Anonymous
  • 611 Answers
  • Posted on Jun 14, 2008
SOURCE: Dynamic DHCP Client List
give a min
Anonymous
  • Posted on Jan 08, 2009
SOURCE: DI-624 problem with wireless network
Buy the N router! That is the only solution. My signal weakened and went from the whole home to less than two feet if that at times. I bought the N router and it worked just like the G one did when I first bought it. Ya think somebodies got the limited life span worked out?
How many devices can connect via wireless to D-Link DI-624?
It can connect as much as 10 computers or wireless networking devices. As long as your base connection is good you can connect as many devices as you can. Because the wireless technology is unlimited and limitless.
Can't connect d-link D!-624 after having computer serviced
Is it the only PC on your network that couldn't go online? If it is, then the drivers for the PCs network card may not be installed properly. Go to device manager to check if drivers were properly installed (Right-click My Computer-Properties-Hardware-Device Manager-Network Adapters).
I'm having an issue with my DI-514 wireless router. I can connect fine when the router first boots up. My laptop will stay connected to the router all day. The problem happens when I disconnect from the...
Open Device Manager. In the Device Manager window, click the plus (+ ) sign next to Network adapters to expand the selection. Under Network adapters , click to select the appropriate wireless LAN adapter. On the menu bar, click Action and then click Properties . In the Properties window, click the Power Management tab. On the Power Management tab, click to uncheck the box next to Allow the computer to turn off this device to save power . Some WLAN adapters have another power saving setting in addition to the one on the Power Management tab. Click the Advanced tab and try to locate a power saving setting. If it exists, disabled it. Click the OK button.
Network is "Hidden"
Try a router reboot.
1. Unplug the Router
2. Shut down and restart the laptops, unplug the XBOX for 20 secondes even though its working.
3. Replug the router.
If this doesnt work you can try resetting the router to the factory settings.
Follow the link below for step by step resetting procedure.
http://www.geckoandfly.com/5890/reset-d-link-router-factory-settings-and-default-password/
Necesito instalar el driver de este D-link AirPlus
1. after power on you can connect your device to laptop or desktop through ehernet cable or wireless mode.
2. set your network adapter on automatic IP reconize mode and after get IP address you can configure your wireless device with 192.168.1.1 Ip address.
Hp Pavilion dv6929nr not connected with D-link DI-624
There are a number of factors that can cause the signal of your access point to deteriorate and the performance of your network to fall under par. Practically any appliance that operates on the same frequency level (2.4 GHz) as 802.11b or 802.11g can cause interference with your wireless network. Be sure to keep cordless phones, microwaves and other electrical equipment at least 1m away from the access point. Try changing channels on the access point and test it out on one of the clients. To change the radio channel on the access point login to the configuration (usually a web based interface) and go to the Wireless Settings (will vary depending on vendor) section, select a different channel and save settings. On the client, go to Device Manager, right click your wireless network adapter and go to Properties. In the advanced tab select the Channel Property and change the Value to the same number as the one you chose on the Access Point. Disable and then re-enable the wireless connection. Also you can try by select the speed manually 802.11b or 11Mbps on your laptop wireless properties.
PLZ GIVE RATING BY CLICK ON YES or NO.
I need to configure my d-link for wow downloader
To configure D-Link DI-624 Wi-Fi access point to work with BitTorrent you have several options. One of them is to use trigger ports.
Steps to follow:
  1. Open web control panel of D-Link DI-624 by connecting to http://192.168.0.1 (this is default direction, which can be changed by administrator).
  2. Enter login and password for administrator. Default login for administrator is admin.
  3. Go to Advanced, select Applications.
  4. In Applications screen:
    1. Check Enabled.
    2. Fill BitTorrent in Name.
    3. In Trigger Port put 6881 and 6999.
    4. In Trigger Type select TCP.
    5. In Public Port put 6881-6999.
    6. In Public Type select TCP.
    7. Press Apply.
  5. The DI-624 will reboot.
Now you can use BitTorrent from any computer on both LAN and WLAN local networks in automatic way.
BitTornado Setup If you use latest experimental BitTornado client you can give a good use toUniversal Plug and Play (UPnP). You just need to enable UPnP on D-Link DI-624 and BitTornado will work on any computer in your local network without any requiered intervention from your part.
In BitTornado:
  1. Run BitTornado
  2. Click on Prefs
  3. Locate UPnP Port Forwarding and select type1 (fast)
In DI-624:
  1. Log in as administrator
  2. Open Tools (main menu)
  3. Select Misc. on the left
  4. Locate UPNP Settings and select Enabled
X-Box 360 Wireless Connection
you just check the network. properties try then un plug the cable of the wireless connection, upter a 5 minutes plug it on
Internet Connection
try a cross cable between di-624 and westell dsl router.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
