Question about Samsung ML 1710 Laser Printer
Samsung 1710 stops before printing
My 1710 goes through the customary warm up before printing, sounds as if it is going to print, then stops and the red light goes on.  I open and close the paper drawer and it goes through motions again and stops.  After several such attempts opening and closing the paper drawer it will finally print, sometimes one page, sometimes all.
  • 2 more comments
  • Docdreyfus Oct 29, 2007
    The solution offered does not help.
    Cleaning the roller did not help. The diagnosis may be correct, but the solution is not.
  • Docdreyfus Nov 04, 2007
    It seems that if I am going to spend the time and money on trying to repair the unit in this way, with no guarantee that it will work, I would be better off just buying a new printer.
    Tried a new toner...same thing happens.
    Scholar:
  • 121 Answers
Here are the part #s for feed rollers.  Replace them and your problem will go away.  Sorry, there's no easy fix in this case.
JC6600526A
JC6600598A
JC7201231A
Posted on Oct 30, 2007
  • Eric Engel Nov 04, 2007
    Yeah...paper jams generally don't go away until you've replaced the rollers. Even if you can make it better by cleaning them, the problem always seems to come back. In this case, I'd say that the printer itself isn't even worth the money and time it would take to replace them. Find one on ebay so you can get your money out of the ctgs.
  • 1,113 Answers
Sounds like the printer is having trouble feeding the paper , it tries then fails to feed paper and goes into jam.
Locate rubber feed roller (usally grey or black about a inch wide should be , lower front above paper tray, whipe this rubber roller with a slightly damp cloth and try again
You could also verify if this is the problem by feeding paper via bypass instead of paper tray
Check to make sure error light is not indicating no toner and that is what is stopping printing
Posted on Oct 29, 2007
  • 3 more comments
  • Soulvisitor
    Soulvisitor Oct 30, 2007
    ok lets work this out, When disconnected to pc and you power up printer does it go to green ?
    if you press and hold the cancel button machine should print a stand alone test print does it?
    If machine does come to green but test print fails to print, try inserting paper in manual bypass (slot at front) and holding cancel to print test, does it print from bypass?
    Or machine starts up but goes to red before printing then, check to see if it goes green when paper is placed in manual feed?
    Hang on brain wave, there are two lights on your machine and I take it that we are seeing the online light full on red, not flashing, that can indicate 3 things with these, jam, cover open or da de de da our problem the toner is out, and thats my conclusion so far the - toner is out, I'm thinking that way cause you have been able to sometimes get it to work, pull that cart out and shake it gently from l to right reinsert, do we get a green light? Replace cart.
    p.s. if you have already been doing that or shutting door causes toner to move in cart. then cart is probally totally MT, never go green.
    p.s. paper feed roller rated life is 60000 prints
    cartridge life is 2000-3000 prints once changed once, the first cart lasts a max 1000 prints
    There is a status monitor that comes with original disks (or downloadable) that gives more specific info on faults occuring with this device it is just part of the software that is issued with machine.
    Are you hooked to this machine via usb or network?, if network you can type in the ip address of this printer in explorer and see info and settings
  • Soulvisitor
    from the user manual.....
    On Line/Error
    LED lights red
    • Paper jam occurs. To solve the problem, see
    “Clearing Paper Jams” on page 6.7.
    • The front cover is open. Close the front
    cover.
    • The toner cartridge is empty. Remove the
    old toner cartridge and install a new one.
    See “Installing the Toner Cartridge”
    On Line/Error
    LED lights red
    cover.
  • Soulvisitor
    r prob is feed rollers then manual feed should still work cause it uses a different set of feed rollers.
  • Soulvisitor
    Soulvisitor Nov 04, 2007
    Get new Toner!!
  • Soulvisitor
    you can prove if it is the feed roller by printing using manual feeder tray, this uses different feed rollers
  • 78 Answers
To fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
2 Suggested Answers
  • 121 Answers
SOURCE: Samsung 1710 stops after warm up
Chances are, you're getting paper jams.  Try cleaning the rollers (as indicated below.)  If that seems to help the situation, then you'll need to get new feed rollers.
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
I have a Samsung 1710 laser printer. It prints the text fine but there is a 1/64 (aproximately)wide vertical line of broken printing on the right side of each page. Also, the paper does not appear to be...
Sounds like the printer cartridge is bad. The first thing I would try is replacing that and then see where you are. The broken line on the right side is likely due to a worn imaging drum coating, common with Samsung.
Feb 05, 2010 | Samsung ML 1710 Laser Printer
Samsung ml-1710 printer does not always print
you need to reinstall printer with samsung printer driver specific for this model that can be downloaded from samsung website
Oct 04, 2009 | Samsung ML 1710 Laser Printer
I have a samsung ml-1710 laser printer. Was wrking
Power off the printer, disconnect/reconnect the printer cable, power on the printer, reboot your workstation.
If that doesn't work, in Control Panel - Printers, delete the icon for your printer. Disconnect the printer cable. Reboot your workstation and log in. Reconnect the printer cable and see if the printer is recognized. Install the printer driver.
Jun 12, 2009 | Samsung ML 1710 Laser Printer
Samsung ML 1710 won't print second page
i'm thinking it's a config-related problem. i've seen a comparable problem already. could you check the settings in the printer software? there is setting that says "print first page from different tray" if its box is checked, the printer wants to print the rest of the print job from another tray, and will block when there is no other tray available.
if you find this setting is not marked, then i propose to delete the printer driver and all settings and then downloading the most recent driver from the manufacturer's website and installing that one.
May 25, 2009 | Samsung ML 1710 Laser Printer
Samsung ML-1710 Printer: Online/Error (red) lite ON: won't print
It is not a computer problem, when your printer won't come to ready. The lights flashing are due to a failure of some sort - electronic, or perhaps a fuser warm up problem. The fact is, whatever the fault, it is cheaper to replace this printer than have it repaired.
Mar 16, 2009 | Samsung ML 1710 Laser Printer
Loud banging noise
encoda strip at the back of the carriage has come loose locate it and place it back be careful as if the strip breaks so does your printer.@ hope this was helpful
Sep 01, 2008 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer, over active feeding
sounds like there's something in the print queue..disconnect it from the computer, and try it again.
Feb 19, 2008 | Samsung ML 1710 Laser Printer
Thankyou,
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer Logo
410 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
