Question about Eureka Whirlwind 4496 Bagless Upright Cyclonic Vacuum
Vacuum Cleaner sucking dirt out of the cannister instead of into it.
I just bought a Hoover Vacuum cleaner from a garage sale.  When I tried to use it I noticed nothing was going into the cannister.  I checked the vacuum and found it to be clogged.  I took it apart and cleaned it out.  When I tried to vacuum again there still wasn't anything going into the canister.  I took the cannister off and turned on the vacuum.  When I placed my hand over the hole where the dirt is supposed to go into the cannister I found it to be sucking in air instead of blowing it into the cannister.
If you can help me with this problem I would appreciate it.
  • 281 Answers
Re: Vacuum Cleaner sucking dirt out of the cannister...
Where you put your hand is supposed to ****.are the filters dirty?if so clean them.disconnect the hose completely from the vacuum and see if you can blow through the hose,if you can't blow through the hos then the hose is can run a garden hose through it and turn on the water and clean it out.but be sure to let it dry ovr night before using it otherwise the dirt will cling to the hose and clog up again.please leave feedback
Posted on Jul 02, 2009
  • 1,673 Answers
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Posted on Feb 17, 2008
0 characters
3 Points
Why won't it suck
Hey there! It's possible that you may still have a clog in your vacuum somewhere. The filters can also cause the vacuum to lose suction. Try these steps to restore suction to your cleaner.
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Rinse the filter under running water until it runs clear. Allow 24 hours to air dry outside of the vacuum.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brushroll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
Jun 20, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Doesn't seem to be sucking up dirt well
Bagless vacuum cleaners leave the bulk dirt in a receiver, but they still rely on a paper air filter to trap fine particles of dust. All the air that the vacuum moves passes through that paper filter. When the filter plugs up, it has to be cleaned or replaced. The bagless "primary filters" are much more expensive than vacuum cleaner bags, but if you can afford to replace it whenever the machine's suction is impeded, its the tidyest solution. You can remove the filter and tap it inside a waste can to dislodge some of the dirt that's plugging it. You can use another vacuum cleaner to clean it somewhat better than just tapping it. (It doesn't have to be *your* other vacuum cleaner, it could be borrowed, at the car wash, etc.) You can use compressed air to almost all of of the dirt plugging it, but you'll want to do it outside somewhere that making a clod of dust is acceptable or at least unnoticed. After a dozen or more cleanings the pores of the paper filter will become too plugged to clean well even with compressed air and it will have to be replaced.
Pet hair, sand and large particulate are least likely to plug these filters. Kitty littler, which is pressed pellets of fine clay, clogs these filters very rapidly. The clay pellets break up into very fine dust as they pass through the vacuum and whirl in the dirt cannister. Avoid vacuuming kitty litter, or any other fine clay into a bagless machine as much as possible.
Jul 28, 2012 | Hoover S3765-040 WindTunnel Bagless...
Brought a dirt devil envision vacuum cleaner yesterday, assembled it and tried to use it. as i am running it, the dirt/dust seems to spread on the carpet/nothing seems to go in the dirt camister. The...
Fro what you say, the unit is blowing instead of sucking, There must be a pipe that is connected to the wrong outlet. Feel where there is suction instead of pressure, that is where your vacuum pipe must be connected.
Jan 30, 2011 | Dirt Devil Vacuums
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
Suction problems
sounds like a clog right near the front
Nov 14, 2008 | Hoover Elite U5061-900 Bagged Upright...
Eureka Whirlwind 4496 Bagless Upright Cyclonic Vacuum Logo
535 people viewed this question
Top Eureka Vacuums Experts
Ryan S
Ryan S
Jim Parker
Jim Parker
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
