Question about Disney Telemania CLEANERS-CLOCK 020099 Cleaners Clock
Pendulum The pendulum is broken off from the attachment. It will not attach and the magnet is missing.
  • 4,102 Answers
If you take it to a clock repair shop they should be able to repair the broken part and replace the magnet as you cant get the parts for this they have to be made i spoke to my locall repair shop and they said they could replace the magnet with an identical one and could repair the damaged part this is the only way u can do this as they dont sell the spares anyware i have used all my contacts and can find no one who can get these parts sorry i couldnt help you any more hope this is some help to you but you can get this repaired for a fee..............................
Posted on Oct 30, 2007
How to fix the pendulum on an elgin quartz anniversary clock
I am unsure wha you mean by "fix the pendulum". If you mean it stopped swinging, there are two reasons: first check the battery and contacts. Remember, even a new battery can be bad, which is why new things come with warranties. The other thing is quartz movements usually don't last too long. If the pendulum is not swinging, and is correctly attached to the movement and the battery is good, then the movement has gone bad and you need a new one. Most all clock shops keep quartz movements on hand. If you are a do-it-yourself type, you can get them off the Internet. Be sure to remove the old one first and check how thick the dial is, that's how they sell them by dial thickness.
Oct 26, 2017 | Elgin Watches
How do i connect pendulum to grafather clock?
How to Attach the Pendulum to Grandfather Clock Hunker
How to remove and re hang longcase clock pendulum
If there is an identifiable maker of your clock, I would recommend you attempt to locate instructions pertinent to it. Perhaps there is additional help in a forum.
Grandfather Clock Forum for Clock Lovers
Sep 01, 2017 | Home
There seems to be something missing from where the pendulum attaches, but i cannot figure out what. Can you help?
It is probably a pendulum leader or pendulum suspension spring. Google booth of them and it will help you determine which one you need.
Tim
UsedClockParts.com
May 08, 2016 | Home
How do I remove the broken end of the tach drive recessed into the end of the camshaft on my massey ferguson 65 diesel
Hi Bill:
Here's a trick you might try. It should work if the broken part is not physically attached and if it is magnetic.
Find a short piece of plastic tube, even a drinking straw will do, that will slide into the hole.
Find a common nail that will just slide into the tube. Grind the pointed end off the nail so it is flat.
Slide the plastic tube over the nail also that it bumps into the head, then cut the tube off flush with the flat end.
Slide the tube with the nail in it into the hole in the end of the crankshaft.
Take your handy super magnet and touch it to the head of the nail.
If you are lucky, if you gently pull the nail/tube out with the magnet attached, the broken but will come out.
Hope this helps.
Feb 04, 2016 | Diesel Toys
What is trouble code 41 for 1988 olds 98???
It indicates a problem with the cam sensor. The problem could be a defective cam sensor or it could also be the magnet attached to the cam gear that the sensor detects. They have a history of falling off after many heating and cooling cycles. If the magnet (about the size of a dime) is missing, replacing the cam sensor won't help. The magnet will need to be replaced.
Oct 13, 2015 | Cars & Trucks
How do i reset the chimes for a Strausbourg Manor Quartz Movement wall clock? and what is the magnet for?
Try removing the batteries. Set clock to 5:45. Reinsert the batteries, and set to 6:00. it may take an hour for the clock to sync., but it should do the trick. The only thing I can think of for the magnet would be that it may have fallen out of the pendulum swinger where your pendulum hangs. Hope this helps. Good Luck.
Nov 07, 2014 | Home
"Wasteunit miss" message and waste unit is perfectly positioned
The waste unit is sensed by a small magnet attached to it (location depends on model) the magnet closes a reed switch on the main unit and closes the interlock so coffee can be made. If in fact the magnet is there - then the reed switch is probably faulty or may need to be adjusted to sense the waste unit.
Apr 06, 2014 | Miele Coffee Makers & Espresso Machines
Disney Telemania CLEANERS-CLOCK 020099 Cleaners Clock Logo
111 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
