Question about Samsung YP-U1 MP3 Player
LOOSE CONNECTION AND CANT CHARGE MP3 PLAYER - Samsung YP-U1 MP3 Player
Why won't my mp3 coby player won't charge
Your coby is not charging anymore..The battery probably needs to be replaced with a new one..Please check your connection when you charge it..There should be an icon that shows your battery is charging. If it does so that means your coby is charging but your battery cant store the energy anymore.
Feb 19, 2012 | Coby MP-610 MP3 Player
No power
The possible causes of the problem are:
1. Dead battery
2. Loose wire connection
First, try to charge the player and see if the battery could hold a charge. If not, then connect it to the computer and try to turn it ON. It the player did not turn on, then it's a dead battery.
But if the player turned on while it's connected to the computer, then it's a loose wire connection.
You may remove the cover of the player and re-solder the connection between the battery and the wire.
Thank you and good luck!
Jun 18, 2010 | Philips GoGear Flash MP3 Player
Player is not switching ON
There are only two possible causes why an MP3 player is not switching ON.
First, a dead battery. Most MP3 players have built-in battery, and in order for you to test the battery, is to try to charge it and see if the battery can hold a charge. If it's not, then you need to remove the cover of the player and see if you can replace the battery. If the new battery works, then you know the cause of the problem.
Second, if you're able to replace it but the same problem occur, then it could have a loose connection inside.
If you're not sure how to test it, then take the player to the authorized repair shop.
Jun 18, 2010 | Creative Technology Creative Muvo T200 ...
Wont charge from a wall socket
the AC to DC adapter might be out of order, check it up
Apr 09, 2010 | Philips SA5245/02 Digital Media Player
RCA MP3 M208 won't hold charge -- Only about a yr old
either the battery pack itself is bad, or the ribbon connection cable that attaches battery to main circuit board is faulty, broken, or loose. It is common.
Nov 11, 2009 | RCA M4208 MP3 Player
Sandiskmp3 player
it may be a loose battry connection. try opening the player and reseating the battery. if that does not work, you may have to get a return from sandisk if your warrenty is still valid.
Jul 28, 2008 | SanDisk Sansa E280 MP3 Player
Loose USB connector, Archos 504
There is nowhere, except in Philadelphia - and they will charge you as much or more than Archos. Mp3 players do not have economical repair services.
Jun 26, 2008 | Archos 504 500870 Digital Media Player
Wont charge
Is the battery button on? If not look on the bottom and charge it with it on "on"
Perhaps connection is loose
Feb 08, 2008 | Toshiba Gigabeat MEG201 MP3 Player
Charging
Sounds like the usb port has loose connection.
Nov 13, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Samsung YP-U1 MP3 Player Logo
27 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
