hello error concerns that there is insufficient fusion temperature, heat lamp revises open position and condition of the thermistor and thermostat connections general..etc
1087 1087 to enter with pressing (163) / print> stop / clear you press (001) and ready.
Unfortunately the error that you getting means that there is a problem with the hard drive. So you will need to replace the drive in the system. Note the D620 uses a SATA drive.
Let me know if you have any more problems or questions
are you sure it is 620? not 6020 or 6200? try hitting 1087 two times on the keypad, that is maintenance mode now type 906 and start button or execute and start button. that will reset a fusing code. that is the only way to reset those codes for safety reasons.
this is a fuser error meaning that the fuser has overheated. In most cases the thermal fuse or thermostat blows and will need replacing. especially if you get the 630 code, and switch the machine of and back on and get a 610 code.
