Computers & Internet Logo
A
Anonymous Posted on Aug 16, 2017
My shop was closed for 6 weeks during Christmas and New Year period ie half of my business period did not have any electricity consumption. However, my electricty usage was the same as the previous period. I called Simple Energy and they said that the usage was accurate as it was from smart meter. Can this problem be caused by the smart meter or Energy operation?
Bill Boyd
Level 3:
Top Expert:
  • Computers & ... Master 53,816 Answers
  • Posted on Aug 16, 2017
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11933686
Points
172802
You did not mention what sort of business you run
if it has commercial fridges or cool rooms , they still use power
if it was a book shop the power consumption would be about 90% less as all that would be running is the security lights and security systems
smart meters can be circumvented so get in a qualified electrician to check that power is not being stolen and then get in a lawyer
5 Related Answers
Anonymous
  • 447 Answers
  • Posted on Dec 05, 2007
SOURCE: TFX24PRXBWW GE Profile Refrigerator - energy use?
I dont know how to locate these specs for you, modern refrigerators are much more efficient for a couple of reasons. Most new units have a Computer that controls the defrost cycle whereas older units have timers that defrost every 8 hours of on comp run time regardless of whether it needs defrosting. The new ADC (adaptive defrost control) can better monitor the frost on the coils to defrost less (in the defrost cycle it consumes 5x as many watts as when its cooling. Also most new refrigs, especially new GE units have much more efficient fan motors now also, however they too are computer controlled and when they fail they are expensive. Also the very high end new Counter depth models (in the $2500+ range) have a new variable speed compressor. This gives the compressor the ability to run at a low, med, and high speed, reducing even more the watts that will be drawn in normal operation when the fan motors are on low and the compressor too. If you have any other questions let me know ill be glad to advise.
P.S. Buy an extended warranty with any new appliance you purchase! Trust me!
Anonymous
  • 42 Answers
  • Posted on Mar 28, 2008
SOURCE: Our refigerator is not cooling .
Hello Laura,
If you look at the rear wall inside the freezer compartment down low and find a bunch of frost on that wall, you have an automatic defrost system failure. The most likely part that has failed is the defrost thermostat. It is located on the top of the freezer coil, clipped onto a piece of tubing. It will have 2 wires coming out of it and it is about the diameter of a quarter and about 3/4" tall. To test this part you would need a test meter and enough skill to check if the contacts are closed when the thermostat is frozen withing the specifications stated on the thermostat. I believe yours would close at 25 degrees F and opens at 47 degrees F. Part # 5303918214
I hope this helps you. supertechks
Anonymous
  • Posted on Nov 24, 2008
SOURCE: Tripping the electrical Breaker
I have used the charbroil bullet electric H2O smokers for years (wore 2 out - currently on my 3rd). I won't use anything else (having used many, many others - HOWEVER - as with every product made there are things to watch or overcome. Learn to use it properly and look forward to many years of great BBQ.
Ambient (outside) air temp below 70 (depending on wind also) will affect these smokers drastically - highly recomend getting or making a "smoker blanket" (got mine at cabelas years back - if you can't find one welding blankets from an industrial supply store can be made into one) to insulate the sides - this drastically reduces heat loss and reduces the electrical load.
Another MAJOR mistake many people make is extension cords - avoid the use of them at all if possible - if not possible then purchase the heaviest gauge you can find.
Always pre-heat your smoker - Always use boiling water (or other liquid) in the H2O pan added after smoker is pre-heated - Always minimize opening the smoker once cooking has begun.
The heater element can be cleaned when cold with a very mild detergent and room temp water.
If you have the large 2 rack but are only smoking enough to use a small amount of rack space on only one rack remember that you are heating a whole lot of air - i have a couple (different size) wood boxes wrapped in foil to take up excess air space - this means less air volume to be heated and better heat control - DO NOT use cardboard boxes or other low temp combustable items in the box construction!
Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet on a 20 amp breaker.
Finally, make sure your smoker is level and remember there can be up to a 20 degree cooking temp swing in temp between the bottom rack and top rack (top rack 5-20 degrees hotter than bottom).
The heater element will cycle on and off during normal use.
Good smoking and enjoy.
Anonymous
  • 40 Answers
  • Posted on Mar 05, 2009
SOURCE: Astar's phone and website cant' be found
Hello everyone,
I worked for Astar Company before as an electronics technician till they are closing down (in Balwin Park, California.) I know all model of the Astar TV, portable and the DVD player. Call 323-767-6030 and I will help you through it.
Anonymous
  • 55 Answers
  • Posted on Sep 21, 2009
SOURCE: Energy consumption of 1.5T LG intelloair split A/C
your energy consumption will be the exact same the capacitior does nothing to alter your systems operation. a capacitior is a voltage absorbing unit that provides ample power for a mechanical device when it starts. the only way to lower your energy consumption from the largest appliance in your home is to buy a more efficent one with a high SEER or EER rating.
Will geminis be luckier in 2017?
2017 is beginning with some new opportunities for Gemini. While some challenges will make your journey a bit tough but all these are essential for your growth. As the Gemini horoscope for 2017 suggests, you need to open up your wings to fly with self-confidence in order to achieve growth and prosperity. Your luck would support you tremendously and the hard work you put in will play important role in your success during 2017.
Gemini horoscope for 2017 indicates that you should share your thoughts with others to let them understand you and your abilities to get recognition. During 2017, you may have to opt for relocation due to work as a new residence is on the cards. All these changes are quite evident in our forecast for Gemini 2017.
Health of your mother may give you some mental worries, but on the other hand, your father will succeed in his endeavors. You will have a religious bent of mind this year and may spend on virtuous pursuits. As Horoscope of Gemini for 2017 foretells, April, second fortnight of August and December will be quite crucial, as your decision-making ability would be weak during these periods. During these periods, you need to avoid taking any important decisions. You could rely on January, March and September to make any important moves in life.
Finally, 2017 is approaching with new ideas and frequent travels. You may be quite fond of travelling to new places and exploring natural beauty this year. You may also develop hobby of photography or acting during this year and it will soothe your soul.
Gemini 2017 career and business horoscope: You will get recognition in career, especially during February to May end and thereafter from October onwards. Mental distress would increase, as work pressure would demand much of your time and efforts. 2017 Gemini career horoscope depicts that during this year, you may change your job location or company and it would lead to rise in your career. Your boss or seniors may have an aggressive attitude that you need to tackle with patience. Team members may conspire hence; do not depend much upon them for work and do things on your own.
Gemini business horoscope 2017 forecasts that if you were dealing in fields such as heavy machinery, oil, mining, gas, automotive parts, you would get tremendous success during this year. In other businesses too, you will succeed as you will take wise decisions and your ideas for competing against your market rivals will be fruitful and beget very good results.
This year will bring good hike in your position and planets would let you excel with your abilities & perform well. During 2017, you will get tremendous success and all you need to do is keep a kind attitude.
These are generic results based on the 12 Moon Signs. Our experts could analyze your personal horoscope to predict what 2017 has in store for your career and business. You can order below.
Jan 04, 2017 • Horoscopes
What If My Business Is Closed For A Period Of Year Due To Seasonality?
In case your business is closed for a few months of the year, the lender will modify a cash advance on your specific state of affairs. It's best to contact your lender before opening your doorways for the season in order to maximize the cash advance size.
2answers
If The Interest Rates Drop Down, Can I Re-Fix A Loan With A Fixed Rate?
Yes but really shop around. some have no closing costs, appraisal fee, loan fees, free no charge, not just financing closings costs into the loan total. All costs covered buy leander. No out of pocket costs. so shop around for the best rate and free closing costs.
Hope this helps Mike
I am a 66 year old business student at Waketech. and I have a code for ConnectPlus. I cannot access student login info. My class is Introduction to Business, Course 110, Section 0008. The Connect ISBN...
There is a maintenance period on the site: "The Wake Tech Blackboard server will be down every day between the hours 3:00 AM and 5:00 AM Eastern Time for System Maintenance." Did you accidently try during this period? Check if your system has any firewall settings that stops the site from opening up. If so, allow the site to open by configuring the settings. Alternately, you can go to Tools>>Internet Options>> Privacy>>Sites>>> (Enter site URL) and click "Allow" in IE
2helpful
Smoking at start up and low trottle
engines that sit for long periods of time suffer from hardening of the seals and rust. There is a very good possibility that the valve stem seal will be hard and cracked allowing oil to be drawn down into the chamber during idling and the rings would have been rusty or running in rusty bores so there will be pitting in the bores. If adding oil is not a problem to you then the oil consumption will only get you into trouble with the pollution police.
Poor fuel consumption
And you have done what?
Discussed at a repair shop or dealer?
What advice do you want, you would understand?
Is the car in the shop once or twice a year?
Is one shop familiar with the vehicles history & maintenance?
4helpful
What is the drive cycle for a 1999 vw jetta
The drive cycle is as follows
For all OBD2 VW's
OBD-II Drive Cycle Stages
The OBD-II Drive Cycle is an eight-stage course, as illustrated in the
chart on page 3. An explanation of each step is provided below.
Stage 1: Cold Start-The ECM determines the presence of a cold start
by comparing the engine coolant temperature to the ambient air
temperature during startup. The engine is considered cold when:
• Engine coolant temperature is below 122°F (50°C).
• Engine coolant and intake air temperatures are within 11°F (6°C) of
each other at startup.
During this period, the O2S heater, misfire, AIR, fuel system, and EVAP
monitors run.
Stage 2: Idle 2½ Minutes-Turn the air conditioning (A/C) and
headlights on to help the misfire monitor-the additional electrical loads
help even out combustion pulses. During this period, the O2S heater,
AIR, EVAP, misfire, and possibly fuel system (if operating in closed loop)
monitors run.
Stage 3: Accelerate-Prior to accelerating, turn off the A/C and
headlights (if possible). Open the throttle halfway until you reach
55 MPH (89 KPH). During acceleration, the misfire, fuel system, and
EVAP monitors run.
Stage 4: Steady State Cruise-During this portion of the cycle, the
O2S, AIR, EGR, EVAP, misfire, and fuel system monitors run.
Stage 5: Decelerate-Gradually coast down without applying the
brakes. Also, on manual transmission vehicles, remain in high gear and
do not press the clutch. During this period, the EGR, EVAP, and fuel
Stage 6: Accelerate-Apply ¾ throttle until reaching 60 MPH (97 KPH).
During acceleration, the misfire, fuel system, and EVAP monitors run.
Stage 7: Steady State Cruise-During this period, the CAT, O2S, AIR,
Stage 8: Decelerate-Gradually coast down without applying the
do not press the clutch. During this portion of the Drive Cycle, the EGR,
EVAP, and fuel system monitors run.
You can try this a couple times, but if it doesn't work you should go to a VW specialty shop like the dealer or a shop that does mostly European cars and they can use the scan tool to force the car through readiness.
2helpful
6answers
I have found that Macwynn is now producing the ASTAR LTV-32ASB model tv under there brand but cant find anything out on them
"Loading disk" appears on screen during movie viewing
buy a can of "dust remover air" or canned air , open unit and flush dust from the unit with emphaisis on the underside of the disk tray.. the sensor are dirty the sense the disk insert .
cliff
Grand Canyon Tech
Grand Canyon Tech
