Vacuums
Problem for Vacuums
Generic problem for all Vacuums
Hoover steamvac model #F5857-900
By melz006 on Oct 29, 2007
will not suck up the water from the carpet
Same Problem
May 02, 2009
-   No suction in. I'm just left with wet carpet. It's attached correctly.-   Guest
Jan 01, 2009
-   My steam vac won't **** up water I've tried everything to make sure everything is on the right way, maybe I'm missing something a seal or something. -   ckwbarkens
Apr 05, 2008
-   Motor not performing normally, runs slow and sounds labored. Also puts out an odor that smells like electrical problem. I assume that the motor has burned out. Is it practical for an owner that is "handy" to replace a motor on the Steamvac F5857?-   wada
Best Solution
posted on Feb 14, 2008
Helpful)
reddevil6
Rank: Guru
Rating: 88%, 1772 votes
Is the lid for the tank locked on all the way round? The filter on the underside of this lid should have a 1/4 gap from the lid to the top of the filter. Is the duct in place, front of the tank. Any of these will cause the problem.
Was this helpful?
Yes
No
Popular Solutions for Vacuums
Questions and Unsolved Problems for Vacuums
Answer
my shark is not working blue light indicator is notgetting on itried to leave the cord loose .
Answer
which vacuum works best on Mohawk smartstrand carpet? I've tried, Sears Intuition upright and Dyson.... (More)
Answer
When the unit heats up, steam no longer comes thru the hose or attachments, but starts pouring out... (More)
Answer
whispertone powerhard not working took cover off belt is on motor not turning and light is out
Answer
No manual for Vax Rapide. Cannot use machine as do not know what to do. Need User manual.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Vacuums:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
