Question about Toshiba DKT-2010 Corded Phone
Speed dialing I'm trying to store some numbers in my phone for speed dialing and it seems to need an access code. How do I find out the access code or change it? Thanks, amy mcguire
· Without lifting the handset, press redial button. Press the button on the strip you wish to store the telephone number on. Note that these 5 buttons are position numbers are 100, 101, 102, 103 and 104. 100 is the first button above EXT PICKUP, and 104 is the first button below DND. These numbers can also be programmed using the method in Step 2 below and entering the position number (100 – 104).
· Enter the telephone number. Be sure to program the 9 in front of all local numbers, and 9+1+(Area Code) in front of long distance numbers.
· Press redial.
· To use the numbers stored on these buttons, lift the handset and press the button.
Posted on Nov 14, 2007
Hoi have got speed dial on the main switchboard, so how do i do speed dial from other extensions
There is system and personal speed dials. System is programmed from the main phone and is dialed by using the AUTODIAL button and dialing a 2 or 3 digit code, depending on which system the 7730 is connected to. The other is PERSONAL speed dial, programmed on the 12 buttons on the right side of the phone. Those are programmed at each phone by using PROGRAM pressing the button and dialing an access code (usually 9) and the number then STORE.
Oct 23, 2010 | Panasonic KX-T7730 Corded Phone
KX-Ta824 Speed dialing problem has a FAQ for this model here
In that FAQ, there is this explanation of your problem:
When I tried to access speed dial, it does not call out.
When storing speed dial number of external parties, the stored speed dial number must include CO (outside line) access code (9 or 81…etc) even with direct line access. If the external number is 1234567, you must store the speed dial number as 91234567.
This rule applies to all system speed dial, station speed dial and speed dial key.
It looks like you're just going to have to add a leading 9 to all the speed dial numbers for that function to work.
Nov 04, 2007 | Panasonic KX-TA824PK Phone
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730- assigning speed dialing/one touch. I tried to press prog button and the one touch button..but it gives me an error message "not stored". How to solve this? I have 12 buttons to assign...
It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
Jun 04, 2009 | Panasonic KX-T7730 Corded Phone
Speed dial
I have posted a video showing how to input telephone numbers into your directory. You decide which speed dial entry to use with which phone number. To access Speed dial easily either program a soft key to be an SPD button or the short code is 16followed by the speed dial number. look at 'abbeytel' on YouTube or
May 15, 2009 | Samsung Prostar DCS-24B-LCD Corded Phone
Prostar 816
with the handset on hook dial #06 the display should read MMC DISABLED enter 4321 then 1, press # to enterpress ALM/SD button, dial the 2 digit code 10-98, dial the phone number you want stored ( pressing hold inserts a 3 sec. pause and msg inserts a hookflash) press the ALM/SD button to store the number. repeat the procedure for additional speed dial programming.
hope that helps
Mar 20, 2009 | Samsung Prostar 816 Phone
Setting the date
By programming, these are programs 000,001 and 002 for Date and Time, Speed Dial number, and Speed Dial Name.
Date and time programming is easy, I don't wish manual speed dial entry on my worst enemy. However, if you like a challenge, I'm going to give you a link to the programming manual.
Start with page 12, since you'll need it to get into programming.
Your key sequences begin on page 16. After you put the first 5 or 10 speed dial numbers and names in, you'll get the hang of entering names in the directory. Nothing changes until you press ENTER or STORE. Each speed dial number starts with a trunk access code (usually 9) as part of the number. In name entry, each time you press the key it changes a letter. In a TDA IIRC 7 presses of the 2 key will get you ABCabc2.
Mar 19, 2009 | Panasonic KX-T7630 Corded Phone
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
Speed dial access
It's easier if you have access to the database to put in names with the numbers, but in the simplest sense, you can take a piece of paper, write down locations, and start entering numbers.
They are added in sytsem speed dial from the first extension or one designated as the manager's phone. PROG **1234 gets you into programming and 001 is the system speed dial area. With a combination of NEXT's and ENTER, you can be looking at SD 000 (ie PROG **1234 NEXT NEXT ENTER NEXT) and you're ready to enter a speed dial in bin 000. The complete number starts with an access code (9) plus the number as you would dial it. For example 918005551212 ENTER puts that number in bin 000. NEXT will step to 001.
Press INTERCOM or select a line and press AUTODIAL and dial the 3 digit code. If your installer was lazy, you will have a problem as "9" selects the highest line in a trunk group, one that you might not have. In that case, he'll either have to program the system properly, or you will always have to pre-select a line to use speed dial.
Notice that this is just hte instructions for SYSTEM speed dial. I guessed that it was what you're looking for. Personal speed dial is a different set of instructions and it could be either under a button or in your 10 or 100 number personal directory (so that's where the 2 digit SD's went :-))
Anyway, if you need those instructions and can't find them in the user manual, please post back.
Nov 21, 2008 | Panasonic KX-T7630 Corded Phone
Speed Dialing KX-T7453
Part of the number you store in your speed dial has to include a "9" or 8x access code to get an outside line.
Sep 18, 2008 | Panasonic KX-T7453 Corded Phone
Toshiba DKT-2010 Corded Phone Logo
161 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
