This is for the mfc5440 but should work I would really need the cleaning absorber pad replaced but takes a bit of getting to. - Machine off - Switch on the machine while holding down the ?menu?button until all the leds are flashing on/off. Now you are in ?maintenance? mode. - press 80 - press the ?mono start? button several times until you see ?purge: xxxx? - press ?2783? in order to reset the purge counter. You will see: ?purge:0000? - press the "stop" button. - press ?99? to exit the maintenance mode.
I have DCP-330C it appears unable to clean 46, how to fix this?
Warning light at my printer..how to fix it..
SOURCE: unable to clean 46
Unable to Clean or Machine Error 46 means your purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET or OK
b. 0 then press SET or OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET or OK
b. 7 then press SET or OK
b. 3 then press SET or OK
This is to reset the purge counter. Then press stop
5. Using arrow up button look for the following:
a. 0 then press SET or OK
b. 1 then press SET or OK (To reset unit)
a. 9 then press SET or OK
b. 9 then press SET or OK (To exit Maintenance mode)
SOURCE: clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
Brother 165 Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide". I went to user's guide and cleaned all the parts inside the printer. Still flashing message. How can i clear ????
SOURCE: clean unable 46 my printer is Brother MFC-295CN
printer head not working new head required. call : 09425386687 or email - [email protected]
