Question about Asrock ALiveNF6G-VSTA (MB-ALVNF6G) Motherboard
Sony Vaio pcg-fx140 wont boot.
This computer is 7years old but it's sentimental...
For the last month or so, my laptop has booted occasionally or will freeze and I will need to reset.  It then would take 15 to 20 tries to get it to start again.  The other day it froze when I tried to connect to a public wireless connection. I powered it off and ever since has not been able to boot. The power light is on, the fan will spin occassionally, I'm getting power to the cd rom, but the HDD light is very dim.  I have tried many things such as moving the one stick of ram to the other slot, taking the whole thing apart and putting it back together piece by piece to try to isolate the problem..  I should also tell you that the ac adapter on the board failed about the same time that this problem surfaced.  I replaced it by sodering some speaker wire and a jack to the area where the jack was. This solved my power problem but then this happened.
So the things that I am going to try now is replace the HD (Could it be that it died?) NOte...when it did start it always took me to scan disk saying there were errors...but then scan disk would freeze so I always exited out of it.
Or the motherboard?
Maybe I should buy a new RAM Module?
Or is it something else entirely?
Any help would definitely be appreciated!
Thanks!
c
  • 2 more comments
  • myvaiobytes Oct 29, 2007
    Hi KatFishGR,
    Thanks so much for your quick response!  I followed your suggestion and unfortunately the result was the same.  I unplugged, removed the battery...waited a 5 minutes.  Plugged it back in and the power light lit, hdd light lit (but very dim), heard some clicks ( I think it was the cd rom) and the fan started to spin.  The fan then stopped for a few minutes and started again this time whirring continuously.  That is the state it is in now.
    Is there anything else that it could be besides the daughter board?
    Thanks again for all your help!
    KatFishGR,
    Ok. I just contacted "Geek Squad" of Best buy and they told me that it would cost more to fix then what the laptop is worth.  Gave me a quote of $700.00!
    So, would replacing the motherboard fix my problem or is the daughterboard not included with the motherboard.  Sorry I'm a little unfamiliar with what the motherboard consists of and I don't want to waste my money on something if I don't need to.
    Ebay is selling a refurbished one for $50.00 + shipping.
    Oh and I gave you an almost there...vote...:)
    Thanks!!!
    Thanks for all your help and your knowledge!
    I'll keep you posted on my vaio's progress....
  • myvaiobytes Nov 06, 2007
    KatFishGR,
    I need your help again. I ended up buying the board, installed it, and now all 3 lights come on and then turn off within seconds. Is there a jumper switch on the motherboard? If so, where would I go about finding it?
    any help will definitely be appreciated.
    Thanks!
    C
  • 3 Answers
Hi I noticed your solution to a sony power fx series problem. I think i have the same problem, i replaced the charging board (bought one from ebay and it worked for about 2hrs then i got the same thing again, the cpu fan would turn on for a split second and so would the lights. You mentioned in your solution about a cpu daughter board? I don't have one in mine (just a socket), or are you talking about the charging board, as its the only seperate board thats connected to the motherboard.
Where are these caps that you are talking about are they on the charging board or the motherboard? unfortunately i can not sink much more money into this system, but i can spend a few bucks replacing the caps (yes i know they are surface mount). Any help would be appreciated, i have a fx-140, i just spent 60$ for a wireless card and memory upgrades and i get everything install and then that happens...very frustrating.
Posted on Dec 04, 2009
    Scholar:
  • 90 Answers
Here's some interesting info for you.
Alot of the FX series Vaio's from years back started to suffer from similar power issues. They slowly get worse over time. And eventually, the thing won't run longer than a few seconds if at all.
If you remove the battery and the power cord, let it sit for a few minutes, and then plug back up, does it come on for a brief period??
The most common issue with the FX series, was the CPU daughter board. There are 11 surface mounted capacitors that need to be replaced. These would fail over time, usually due to insufficient cooling. And cause the laptop to sense a false high temp reading from the cpu. The laptop would shut off prematurely. Replacing the caps solved the problem for most. Or simply replacing the CPU daughter board.
I have repaired several of these at my shop in past years. But if you would like to research it yourself, just go to google.com and do some searching.
Posted on Oct 29, 2007
  • Chuck Gluth
    Chuck Gluth Oct 29, 2007
    No, thats more than likely going to be your problem. The fact that the fan runs the way it does is a pretty good hint that those capacitors or the whole cpu daughter board will need to be replaced... getting a false high temp reading when powered on.... quite common with these. That is the only solution. I could repair this problem if I had it here. An "almost there" vote would have been nice... :-) As there is most likely your issue.
  • Chuck Gluth
    I saw this same board on ebay for 49 bux as well... thats a pretty good deal if you ask me :-) id go that route and be done with it... seeing as you had a power jack problem as well, this would also put that back the way its supposed to be. Thats a pretty good price for a used board.
2 Suggested Answers
  • 135 Answers
SOURCE: sony pcg-fx140 bootup problem
1. check bios for first boot option to hard drive.
2. If xp, run repair from cd (enable cd boot in bios).
Posted on Feb 16, 2009
Sony vaio a417m wont boot
If you only want to enter BIOS then you can try the below keys .
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Aug 06, 2012 | Sony VAIO Notebook
Sony vaio pcg 7173L wont turn on
my laptop is sony PCG-7173L. No thing display on screen and i even cant shutdown and there is no power led on power button and no sound of fan too....i cant go to advance boot option also..Please can any body help me...
Jun 16, 2012 | Sony Vaio Pcg-7173l Complete - Core 2 4gig...
My VAIO PCG-7A1M laptop powers up but does not boot up
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Apr 08, 2012 | Sony VAIO PCG-K35 Notebook
I have a Sony Vaio PCG-8A8M with display problems.
sounds like the display/monitor is about to go... backup your files...externally
Sep 13, 2009 | Computers & Internet
Upgrade memory - computer now won't turn on or boot
Follow this link to do it,
http://support.vaio.sony.co.uk/tutorials/memory/memory.asp?m=2108&site=voe_en_GB_cons
Hope this helps
TC and Cheers!!!!!!!!!!!!!
May 29, 2009 | Sony VAIO PCG-K35 Notebook
Booting problems.
try right click desktop go to properties/display setting check that display is set properly go to advanced settings check out there if everything OK go to control panel/device drivers uninstall video drivers reboot it should boot with standard vga drivers check if display is OK then try loading your proper video drivers
Jul 27, 2008 | Sony (B99860307) for VAIO PCG-K series...
Sony pcg-fx140 bootup problem
Jul 03, 2008 | Sony MBX-49 ASSY Motherboard
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Sony Vaio not Booting
Have you tried booting with a windows cd, and then running a disk check?
Dec 18, 2007 | Sony VAIO PCG-K25 Notebook
Asrock ALiveNF6G-VSTA (MB-ALVNF6G) Motherboard Logo
152 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
