Kyocera Copystar CS-1620 Black and White Copier
Problem for Kyocera Copystar CS-1620 Black and White Copier
Check to see if the fuser is working yu should be
By M2Tech1 on Jun 12, 2009
check to see if the fuser is working yu should be able to tell if you open the side door up at the top you will see the fuser orange roller and black.. feel to see of it has gotten hot be careful though it does get upto 180c.. if this is ok then check the toner is set right as it may be trying to load did you give the toner cartridge a shake before you put it in this can sometimes be compacted.. good luck A
Solution #1
posted on Aug 30, 2009
Not Rated)
low_toner
Rank: Master
Rating: 75%, 2 votes
whats the problem?
Was this helpful?
Yes
No
Popular Solutions for Kyocera Copystar CS-1620 Black
Questions and Unsolved Problems for Kyocera Copystar CS-1620 Black
Do you recommend Kyocera Copystar CS-1620 Black and White Copier?
Answer
Answer
how to setup a eStudio 210c to work on a network. Do you plug it into the router or a PC? How do you... (More)
Answer
hi.... canon np7160 need to reset after service??? counter reading indicator was blinking....how to... (More)
Answer
I need to unlock my cell phone so I can get service through my curent provider.It use to be hooked... (More)
Describe your Copiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in , TX
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
