Immediately after entering the year part of the date, the display should revert back to a blinking first digit (in this case, the 0 to the left of the 8) while retianing all the following digits just entered. Simply press the Time/Date key again to lock in that date and stop the blinking. The same process applies for the time.
To clear the display of the time/date when using the calculator to actually compute something, press the C or CE button. This will result in a 0 appearing on the display. The unit is now ready for data entry.
To set the time on this calculator, you must press and hold the time key until the display is flashing 0. (Hint: you will want the date displaying when you are going to set the time as when you press the time key to hold it, it will switch over to the time.) Once the display is flashing you type in the time using the keypad. If you were going to set the time for 9:30, you plug in 930 and push the time key again. If you need to set it for a time in the PM you would have to use the 24 hour scale; for example 1:30 PM would be 1330. To set the date, you press and hold the time key with the date displaying until the display begins flashing. Again you would use the numbers on the keypad to enter the date and press the time key again to set it. For 1/20/2011 you would type in 12011.
Changing the time on a Avaya Merlin Magix system is accomplished
from the system programming console. The date is change separately from
the time.
Changing the date:
1. Press Menu
2. Press System Program
3. Press Exit or Start
4. Press System
5. Press Date
6. Enter the date as: mmddyy where mm = month, dd = day, yy = year
7. Press Enter
8. Press Exit or Back
9. Press Home or Exit
Changing the time:
1. Press Menu
4. Press System
5. Press Time
6. Enter the date as: hhmm where hh = hours & mm = minutes
7. Press Enter
1)Press TIME/DATE and then SET (The first digit of the month will flash)2)Enter the month MM using the number keys.
(The first digit of the date will flash)
3)Enter the date DD using the number keys.
(The first digit of the year will flash)
4)Enter the year YYYY using the number keys.
5)Press SET to confirm the date.
6)Press TIME/DATE and then SET. Enter the time using the number keys and press 12/24 to switch between 12-hour or 24-hour clock.
7)Press AM/PM to toggle morning or afternoon and press SET to confirm the time.
press the CA button to get your time/day from being displayed. For your date... whenever you press the time button to edit your time, press it again & your date shouold come up. the time/date button are both done with the TIME key.
Turn the calculator on.
Hit the "C/CE" button and 0. will display.
Hit the "TIME" button so that the date displays.
Hit and hold "=" button until the month flashes. Now put in your date such as 11182008.
Hit the "TIME" button again so that the time displays.
Hit and hold "=" button until the time flashes. Now put in your time such as 1254. (12:54pm)
Hit "=" button to end.
I recently solved this issue with my calculator
Press and hold the time key when the date is dispalyed. When the display flashes enter the date as a six digit date (example 110608 for November 6, 2008) Time needs to be entered in military time when changing time.
