Question about Micro Pro 7599 Iron
B&D AS 150 is not heating up
Every lights are lighting up correctly and every nobs are working properly but my iron is not heating up.
  • 43 Answers
It's dead the elements inside are now gone. Spend $150.00 on a Phillips gold based iron. You will be very happy with it
Posted on Feb 02, 2008
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
Steam is not getting through to the iron which is heating up ok and generator seems to be working
Could be a possible block of the water jackets to the steamer,ajammed valve .press down the water release nob several times to see if the block clears.Have an air pressure hose connected to the inlet while the nob is pressed.
Sep 29, 2010 | Rowenta DG-920 Iron
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Iron has light on so power is there however iron
You will need to dismantle your iron. Follow the instructions below to locate the fault:
a. Make sure the power cord is not damaged.
b. Then, check the temperature selector. If it is in the correct position, something else is wrong.
c. Check the thermostat. As you disassemble the iron, clean the lint from the thermostat. Then test it with your ohmmeter. Set your ohmmeter on RX1 and clip the probes onto the terminal. Take a piece of wood or plastic and move the contacts open, then closed. When it closes you should see the ohmmeter just from high to zero. It so, it is working well.
d. Test the heating element. Do this by removing the base of the iron. There you should see the probes. Take you ohmmeter, set on RX1, and touch the probes. If it reads between 10 to 25 ohms, it is working correctly.
e. If you have an electronic iron, the only other possibility is the circuit board. If you have exhausted your options, take the iron to a professional.
Thank you.
Sep 28, 2009 | Irons
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
The light is on...but no heat at all?
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Aug 10, 2008 | Rowenta Powerglide DE011 Iron with Auto...
Why isn't my Iron heating up? Just finished filling my Krups V65 iron with water. Was ironing linen shirt on linen setting, all of a sudden, heat dropped all the way down to light one (very low heat) and...
I do believe the thermostat is defective.All the iron have a small thermastat top control the temperature and is working like a switch.If the switch don`t work get stuck on the same position.Unfortunatly sometimes is better get a new one themn fix an old one but this is The Market and nothing i can do personally.Also make sure the thermostat knob is working properly.If you hear a click when you turn is ok.
Good Luck
Jun 12, 2008 | Irons
Tefal Aquaspeed 150
yes unless the thermostats gone.
It,s not really financially practical to replace parts, will cost you parts-and labour.
cheaper to get a new iron, unless still warranted.
Mike @ Compurepair.
Oct 01, 2007 | Tefal Aquaspeed 170 Iron
I have the same problem with my black and decker iron. I will not buy orrecommend this iron to anyone.
Aug 09, 2007 | Sunbeam Safety Glide 3891 Iron
Micro Pro 7599 Iron Logo
107 people viewed this question
Top Micro Pro Irons Experts
Marvin
Marvin
Are you a Micro Pro Iron Expert? Answer questions, earn points and help others
