Question about Garden
Mower blades not engaging
I ran over a piece of rope this mornign when I was cutting my grass. I got off of the mower and cut the entangled rope off of the blades. No more rope is left entangled around the blades, but when I crank it up and turn the lever to turn the blades on the lever turns but nothing happens. Now the mower will not cut grass and I do not know why
  • 66 Answers
Is the mower belt on the pulley ?
Posted on Jun 12, 2009
SOURCE:
My ride on lawn mower is cutting out every time i try to engage the cutting blades
Sometimes it is due to the ETHANOL fuel you are using. ETHANOL is attracting moisture and after a while it builds up water in the tank.
Jul 06, 2015 | Garden
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How to fix Honda HR215 mower from skipping grass
check the belt tension on the deck
Apr 22, 2012 | Garden
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
I have a 1500 series Cub Cadet, 54 inch cut. I ran over a rope that wrapped around the blades shutting down the mower. I turned the mower off and removed the rope. I engage the PTO. I hear it click but...
put the rope back around the blades then go in reverse slowly, park the tractor where you found it prior to running the rope over, get off, shake your head a few times, then try it again, this time pick the rope up first! that should fix ya!
Aug 19, 2010 | Garden
Blades are engaged,but won't cut the grass
Check the blades to make sure that they are not upside down
Apr 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Sep 22, 2008 | Garden
Garden Logo
275 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
