Question about HP DeskJet 1220c InkJet Printer
Hp 1220c window xp driver
My hp rinter dont run on window xp os
  • Anonymous Nov 22, 2007
    can prtint test page from printer but it will not work with auto cad (was
    workong for a year)
    I have uninstalled soft ware and re=installed & still have the problem.
    Is it possible to purchase a new up to date start up disk.
  • Anonymous Nov 24, 2007
    need updated HP 1220c driver software for windows xp
L have hp 1220 deskjet no supported windows xp
Posted on Sep 16, 2008
Required isres.dll file
Posted on Aug 13, 2008
I have hp1220c deskjet no supported windows vista
Posted on Feb 01, 2008
  • 417 Answers
HI goto www.hp.co.uk or www.hp.com and select support and download select the operating system and which printer you are using and the updated driver is available to download.
Hope this helps
Thanks J
Posted on Jan 13, 2008
2 Suggested Answers
SOURCE:
SOURCE: hp 1220c window xp driver
i updated my driver for my hp1220C on XP after a crash that stopped the valuable print preview function working ...(printer worked but was print immediate - -and no tool box options etc) . i can't believe i found how to fix the driver ... you need to right click the exe file [before running it] dj1074en.exe or whatever ... and 'properties' - 'compatibility' click near 'compatibility mode' 'windows 2000' - then run it ... and voila -- i now have the print preview and all the lovely functions back again!!!! crazy!! took me 3 hours to find this ... it may well work with vista -- to select the windows 2000 option .. don't know that one ... at least until HP update all corectly and clearly
marie
Posted on Dec 29, 2007
HP 1220c driver for windows 8 64 bit
All of the HP drivers for the HP 1220C are available here: http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=19142 . For Windows 8 and higher, the driver should be available through Windows Update. Make sure that the computer is connected to the internet and connect a USB cable between the computer and the printer. The printer should be on. If you do not see any activity, try accessing Windows Update and checking for updates manually.
Note: you do need allow Windows to automatically download driver software. See http://support.hp.com/us-en/document/c01796879 for some of the items to check. Additional steps are here: http://h30434.www3.hp.com/t5/Inkjet-Printing/I-need-a-printer-driver-for-my-Deskjet-1220C-to-use-on/td-p/5485192 .
I hope this helps. Some of the Windows Update steps can be slow.
Feb 16, 2017 | HP Office Equipment & Supplies
Hp dj 1220c printer driver refused to install on my windows 7
Try to reset the factory settings: Go to Settings tab and press the Resets option. This will change all the settings to default factory settings. Try to print using another OS and check if there is a difference in the print quality. Try to print in draft mode and in FastRes 1200 mode. Tip and tricks for all deskjet setup
https://123hp.co/hp-deskjet-printer-models
Oct 28, 2013 | HP DeskJet 1220c InkJet Printer
How do i get the Win7 driver for Hp deskjet 1220c printer
Hi
HP doesn't support your device under Windows 7 . Install a Virtual version of XP on your machine :
http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
or purchase a Windows 7 compatible replacement device .
Best regards ,
fanaudi .
Sep 08, 2011 | HP DeskJet 1220c InkJet Printer
Install hp 1220c on windows 7
See: HP DeskJet 1220c Drivers
However, HP says that this printer driver is in the Windows 7 OS. Try doing a Windows update.
Here is HP's Windows 7 information page:
HP 1220c and Windows 7
Thanks for using Fixya.
Dec 29, 2010 | HP DeskJet 1220c InkJet Printer
1220c driver for windows 7
HP 1220c driver for Win 7 is nit working, need help
Nov 09, 2009 | HP DeskJet 1220c InkJet Printer
Drivers
hp website but xp drivers will give you no joy
Jul 22, 2008 | HP DeskJet 1220c InkJet Printer
marie
Dec 28, 2007 | HP DeskJet 1220c InkJet Printer
HP deskjet 1120c professional serias printer
I have the same Printer and it works great in Windows XP Pro, so maybe you need to check their website for updated printer drivers...? My Printer is the HP Deskjet 1120C Professional Series Printer, that's the full name so I guess its the same printer...can print up to 13x19 inches....I've used the heck out of mine and it just now developed a problem where it won't pull the paper in from the front, but believe it or not I can load one sheet at a time from the back....
Dec 19, 2007 | HP DeskJet 1120cse InkJet Printer
HP DeskJet 1220c InkJet Printer Logo
511 people viewed this question
Clive
Clive
Thomas F. Schneider
