just happened to me, i'm sure it has something to do with the heat. When stagedog said he powered off his phone overnight, then powered it on the next day. Sounds like a heat problem, i just took my battery out, and im going to leave it out for a couple hours. Hopefully it will start working soon, i need it tonight!
You might have to align the screen but it its not working at all (the touch screen) it is probably a bad digitizer. You can buy a digitizer on ebay for $7-20
well wen you dropped it did the ink move luiek the colours where were wrong for example the white was pink etc.. if this has happened ,and it is common in touch screen phones, the phone is no longer good you can still keep it if you want but the problems will get worse n worse until its just gone
This is a known issue with the Rumor. If you take your phone into a sprint repair center or call technical support, they will most likely repair or replace it for free.
sir this is a typical problem when water seeps through the phone... may be the servicer havent cleaned it up well.once again ask him to clean it up well. my advice is change the keypads... it might prove helpful.. thank u sir
This usually happens when you drop it, what happens is that when it comes in contact with the floor or hard surface, it can damage the componets without you knowing, you can not tell what exactly is wrong with it unless you take it to a repair shop and if its a major componet you might be better off just buying a new phone, or if you have T-mobile you can call them and they will send you a new phone for free its just when you get the new phone they need your broken or old phone back. Hope this helps. =)
well if you had the phone less than 30 days you can probally try to retern the phone.and explain all the problems
(THIS IS A SUGGESTION)
NOT CERTAIN IT WILL WORK
