Question about Kitchen Ranges
I have a Jenn air dual fuel. The 5 burners on the top will not light without a match. There is no click sound.
Used unit was not installed when I bought it, so no way to test. All the burners will light with a match. The unit was heavily soiled.
  • 254 Answers
If they won;t light on there own after cleaning then the spark module for the burners may be faulty
Posted on Mar 06, 2014
4 Suggested Answers
SOURCE:
  • 2699 Answers
SOURCE: Jenn-Air dual-fuel range model SVD48600B dislpay
you need to change out the clock assy. part number 71001799 and it's around 200 bucks
Posted on Oct 02, 2010
SOURCE: Installation of down-draft exhaust duct for Jenn-Aire cook top
Minimal 6" duct no more than 20 feet long and 90's count as 5 feet. 90's must not be closer than 18" this will meet local codes regarding the venting also an approved exhaust hood. (not a dryer vent)
Posted on May 22, 2008
SOURCE: stove top burner Spectra XL4
rear left back burner clicks to ignite but doesnt
Posted on Apr 06, 2008
Jenn-Air Dual Fuel Range Model JDT8895BAS
The igniter will click on all the burners simultaneously no matter which burner knob is on. This is normal.
Aug 27, 2014 | Cooktops
Several Gas Burner Igniters spark every 5 seconds even when all burners are turned off. Jenn-Air Dual Fuel Range JDR8895AAS Help, and Thanks! -- Larry
hi could be a short on the ignition switch of the spark box is stuck in the repeat mode disconnet power and see if this helps
Jan 23, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My jenn -air self clean over just beeps when i hit clean
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 31, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air dual fuel range JDR8895AAB caught fire last week.
The exact same thing just happened to our same model last night. Did Jenn-Air fix it?
May 07, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Two from burners will not start , unless a match is used
Check the position of the ignitor that sparks, compare it to the burners that do lite.
The other one may ne replacement
Mar 18, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Jenn-Air JDR8895 dual fuel--ignitors won't work after flood
hi your ignitors wont last long, they are similar to a fuse, you should be able to change the ignitor and if it still does not ignite look to see the space of the ignitor and try shorten it.
Feb 05, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Spark ignition clicks every 5 or 10 minutes with burner valves off it is not continus spark it sparks once
Sounds like one of the four switches attached to the burner control knob may have failed where the switch does not fully open. This could be due to moisture or grease having seeped into the burner control/switch.
You can find a wiring diagram for this unit at www.SearsPartsDirect.com by typing in your model number.
Reply back if you would like further help.
Jan 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Igniter of back burner dies not click or light
I had the same issue with washing the top with water and cleaning solution. I had arching, eventually one burner failed to ignite. I tried the above solution and it did not work. Remove the ceramic top on the burner that will not ignite. Turn on another working element. Do you see the igniter working?
If so slowly turn on the gas on the failed burner and it will ignite. I'm looking into what component automatically controls the igniting and gas release when the knob is turned on.
Dec 22, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
All the Burners click when I just turn on 1 knob
The manual tells you this will happen. Just adjust the flame for your intended use and start cooking
Dec 01, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
80 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
