Home | Acer | Aspire 5050-3242 (LX.AG30J.012) PC Notebook | Restore factory set...
Acer Aspire  5050-3242  PC Notebook
Problem for Acer Aspire 5050-3242 (LX.AG30J.012) PC Notebook
Restore factory setting acer aspire 4310
By wawan_924 on Jun 12, 2009
restore factory setting acer aspire 4310
Same Problem
Sep 18, 2009
-   Hi I have a similar problem. Just read the earlier thread about backing up and wanted to make sure that if i backed up everything on my D drive. that this information will not be deleted and will sit there quite safe until the factory setting on my C drive are restored. -   stevecole99
Solution #1
posted on Jul 12, 2009
Not Rated)
rainbowtj
Rank: Wiz
Rating: 95%, 23 votes
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Was this helpful?
Yes
No
Solution #2
posted on Jun 12, 2009
Not Rated)
downie200144
Rank: Master
Rating: 98%, 20 votes
you need to burn all the disks from acer power management click start programs & u shoud see it in there
Comments:
Jun 12, 2009
- you need to burn all the disks from acer power management click start programs & u shoud see it in there
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5050-3242 PC
Questions and Unsolved Problems for Acer Aspire 5050-3242 PC
Do you recommend Acer Aspire 5050-3242 (LX.AG30J.012) PC Notebook?
Answer
Answer
cannot open window files, seems to be locked. message edata security system error reinstall the... (More)
Answer
will not contect to wireless internet when contacted via mains, only when on battery only
Answer
unable to restart laptop to factory settings by alt-f10. how do i restart to factory settings?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 5050-3242 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
