Samsung 32" Series 5 LED HDTV - UN32F5500 Logo
T
Tess Lock Posted on Mar 05, 2014
Samsung led tv off and on
Tv turns off and on
Haywire39
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Aug 16, 2014
Haywire39
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
1709
Points
25
Mine doe too! Just what I want to save power.
Samsung LED 55" TV is not turning on. It turned dark when we were watching it and burning smell came out of it.
I recommend checking with tvpartsguy.com as they have tons of parts and can help you diagnose your tv.
Samsung LED TV, sound but no picture
Have you tried unplugging it and letting it reboot?
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
1helpful
3answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
60 inch samsung led tv turns off and on while watching
it may caused by the dust.
open up the led tv and clean it using the blower.
Samsung LED TV no picture
What could be the most probable cause that the Samsung UN55VFXZA TV has been turning itself off ? How I can fix it?
Samsung led tv troubleshooting guide
i have 65 inch samsung tv LED UA65D8000XN if you plag in red light on if you tuch power ON was blinking then the blinking it will stop but the tv will not turn ON the tv no display no picture relay click about once per second but the tv will not turn on thanks for any solution
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
