Question about HP Compaq 175-Watt Power Supply
Evo D510S Possible Power Issues
I have an Evo D510S that won't boot all the way. How can I test the power supply on these 14 pin units?
  • 1 more comment
  • syracusepc Nov 26, 2007
    The fan turned on momentarily then went down. I replaced the motherboard, as it was cheaper than a power supply & it works now. Thanks for your input.
  • Anonymous Apr 17, 2008
    I have Compaq 14pin power supply.
    In a standerd power supply we can short green & black pins to test it.How can i test 14pin one like that??
  • ravikkhatri Feb 04, 2009
    Same issue,
    Please tell me how to change the these 3 resistor coded with green, brown, silver, silver
    Where i have to connect this resistor
    Problem Solver:
  • 9 Answers
First turn on your pc. Is the 2 led indicator blink? If is not it might be your power supply. B4 that try to change the power cable if its ok or not. My psu got fix with elec.technician, Ive got a fuse blown rated with 5A 250v(size like a miniature mic), and change the 3 resistor coded with green, brown, silver, silver...This kind of psu is not available in my country..Here in the Philippines! It works now..
Posted on Jun 29, 2008
    Master:
    Sergeant:
  • 482 Answers
If it turns the fan, it works, if not its the motherboard, you can find them on ebay
Posted on Nov 26, 2007
SOURCE:
P8P67 EVO Won't Boot with power to board
This is almost always the power supply. How exactly did you "check the power supply"? You checked all 12 or so voltage outs under load?
If replacing the power supply doesn't work, replace the motherboard.
Dec 24, 2012 | ASUS P8P67 EVO LGA 1155 Intel P67 SATA...
AB9 Pro motherboard
do this test this will tell you if your power supply is good or bad we will do the process of elimination ok.
How do I test if the power supply is bad?
Warning This test is for those with extensive electronics training. Do not try this if you do not have extensive electronics training. Make sure there is enough load connected to the power supply before testing ( at least motherboard and one hard drive)!
ATX power connector layout isshown above. 5VSB constantly provides 5V power to the connector through pin 9. If you have a voltmeter, while the power supply fan does not turn on, you could identify which pin is pin 9. Normally there is a clip on the connector between pin 15 and 16. If one can identify pin 14 (the only green wire goes to pin 14), this is the power-on pin. Onee can use a piece of wire to short pin 14 and 15 (or any other black wired ground pin). If you power supply has power connected to it and power switch on the power supply is on, the fan should be turning by now. Otherwise, your power supply may have problem.
Dec 27, 2007 | Abit AB9 Pro Motherboard
My PC power supply crashed, burnt resistors, Powerman IW-P250A3-1 20 pin plug to motherboard, bought new power source, but the old power source had a white cable to the 20 pin plug which was -5vdc 0.3amp....
For your system to boot up properly, you need an identical power supply for your system. Most likely the reason why your system won't boot up right now is because you purchased a different power supply and it is lacking something(which is the other pin).
Regards
Sep 14, 2011 | Computers & Internet
Yesterday my comaq evo desktop was working very well and today i power my computer and it could not display i have check the memory and is ok , so what can be the problem?
check the connections are perfect .
1.power
2.cpu to monitor connection
the os may be corrupted in many cases check it.finally graphics card to be checked by the engineer
Sep 03, 2011 | Compaq Evo D510 PC Desktop
I have an Antec Truepower 2.0 TPII-430. This power supply provides power to the fans but when I push the computer power-up button, nothing happens. I installed another similar power supply and everything...
Test it. Unplug the molex connector from the mothrboard. You can use a wire or a paper clip to test it to power on. You will connect (short) pin 14 to and ground pin. (diagram here) For example, put one end of the paper clip into pin 14, and the other end into 13, 15, or 16. If the power supply turns on and fan running then maybe a problem with the front panel switch on the computer case.
P.S. make sure you unplug all other leads to drives before doing this.
Apr 06, 2011 | Antec : True430 430W P4 ATX Power Supply...
Have hp compaq d530 problems turning on. Wont boot, showing 1 green flash when power button is depressed & thats it!,,,,, ASSISTANCE!!!!!!! johnhall248@yahoo.com
That is most likely a bad power supply but it could also be a bad mainboard. You can find replacement power supplies for under $50 so try that first.
Mar 18, 2010 | HP Compaq Evo d530 PC Desktop
Computer will not turn on. Possible power surge.
If the power supply is good then your motherboard must have gone bad during a surge.
Dec 26, 2009 | Intel D865PERL Motherboard
if it comes on at all, its not the power box but the motherboard
Nov 17, 2007 | Computers & Internet
HP Compaq 175-Watt Power Supply Logo
421 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
