I've searched the web and cannot find help for any service manuals or videos on using the Tally 9035 printer Diagnotics menu to assist with clearing or fixing the 'misfeed jams' , 'exit'jams' that cause this printer to fail and cannot correct the problem. any help or leads would be appreciated.
SOURCE: Tally 2265 paper jam
I am not familiar with this particular printer, but dot matrix printers are not complicated. Being that it is old, it very well be that a sensor is dirty or bad. There probably is only one or two of them. I suggest you carefully take the cover off, and expose the platen roller. If it is removed easily, take it out and clean it with dish detergent and water. Better yet, use WD40, because it will revitalize the roller a bit. be sure to use the dish detergent to get the WD40 film off. Now, look for any small switches in the paper path. Something may even be holding it down. The switch part may only be an actuator, and you may have to follow the arm to the photo interrupt switch. Clean in between the posts of its an interrupt switch. If you can't find anything jumping out at you, its probably time for a new printer.
SOURCE: i m using tally7.2 multi user i m getting internal error memory access violaion exiting tally
Dear navin12,
I also got this same problem in my office, first time i solved this problem through restore the XP to Previous restore point. second time this problem came different machine in that machine restore point not worked, I tried all the ways but no use, finally it will work when i login as different Domain user in that machine, I couldn't solve that problem in that particular user.
SOURCE: platen open error message on tally t6218 line printer
there are two reason behind the problem . 1 .the problem may come from the logic board.
2.and the platen sensor. change the platen sensor. if not solved change the board.
SOURCE: exitting from tally
this problem in taly 9 go 'c:\Tally\Data\10000 and delete tmesege file
problem sole
