Question about Samsung SGH-E900 Cellular Phone
Replacement Fascia I have bought a replacement fascia for an E900 and I am trying to find a guide on how to replace it. Any ideas
  • 1,463 Answers
you could try this link it as images on how to do this
but be carefull if trying this .
Posted on Oct 31, 2007
How do I replace rear parking sensor
You have to take bumper cover off .
Remove rear bumper fascia. Refer to Rear Bumper Fascia Replacement . Disconnect electrical from the rear object sensor. Lift the locking tabs on the housing and remove the rear object sensor.
Preliminary Procedure
  1. Remove the compartment sill plate. Refer to Rear Compartment Sill Trim Plate Replacement .
  2. Remove rear wheel liners. Refer to Rear Wheelhouse Panel Liner Replacement .
Rear Fascia Push Pin Retainers (Qty: 2)
Rear Fascia Nuts (Qty: 4)
10 N?·m (89 lb in)
Rear Fascia Bolts (Qty: 2)
Rear Fascia Bolts (Qty: 6)
Rear Fascia
Energy absorber and fascia are removed together. Cannot be separate on vehicle.
Disconnect the electrical connectors.
Dec 22, 2015 | 2006 Cadillac DTS
How do I replace my rear bumper on my 04 pacifica
  1. Open liftgate.
133387935 Fig. 12
  1. Remove two push pin fasteners per side at the liftgate tower area (Fig. 12).
  2. Hoist and support vehicle with safety stands, as necessary.
133387936 Fig. 13
  1. Disconnect the park assist wire connector under the vehicle and the push pin fasteners attaching wire harness under the vehicle (Fig. 13)
  2. Remove the four push pin fasteners attaching rear fascia to reinforcement bumper.
  3. Remove two screws (each side) attaching fascia to rear fascia bracket in the wheelhouse.
  4. Remove the screw on each side attaching the upper fascia in the tail lamp bucket area.
  5. Remove rear fascia from vehicle by lifting sides of fascia up and outboard to release from rear fascia brackets.
  6. Place fascia on a clean surface.
133387937 Fig. 14
  1. Remove park assist sensors, if necessary (Fig. 14).
133387938 Fig. 15
  1. Remove spring clips attaching upper and lower fascia together (Fig. 15).
  2. Using a trim stick release locking tabs and separate the upper and lower fascia.
133387939 Fig. 16
133387940 Fig. 17
  1. Remove move the bright chrome molding from the upper fascia (Fig. 16). Using a trim stick, starting at the out edge of the fascia release the locking tabs (Fig. 17). Grip the molding and pull outward from the fascia while releasing the locking tabs.
  2. Remove molding from fascia.
  1. Place bright chrome molding in position on the upper fascia.
Jan 06, 2012 | 2004 Chrysler Pacifica
How can I remove the fascia panel from my Neff double oven? I have a Neff U1552 oven. The display-film strip showing the temperature for the fan oven broke. I have bought a replacement part from Neff and...
did you manage to fix your strip, i have the same problem, all4 strips have broken in the last 6 months on my U1552. how much was the replacement?
Jan 02, 2011 | Neff Ovens
Front grille replacement
The grille in the WJ models is incorporated into the fascia. To replace or service the grille, the fascia must be removed. The grille is equippedwith an insert which can be serviced.
For other details and graphic guide, can check the Service Manual Section-23-Body-ewj23S (page 28 and next).
I really hope helps with this (remember rated this hep) Good luck.
Dec 15, 2009 | 1999 Jeep Grand Cherokee
I need info on how to replace the headlamp bulbs on my 2008 Chevy Malibu, can you help.
The procedure is very involved.It requires the removal of the front bumper fascia fasteners from the center and side of the headlamp to be removed.
  1. Remove the front bumper fascia fasteners from the center and side of the headlamp to be removed, full removal of the fascia is not necessary. Refer to Front Bumper Fascia Replacement.
  2. Gently pull the fascia forward to allow clearance to remove the headlamp assembly.
  3. You will also need to remove some of the fasteners at the front of the inner wheel well.
  4. The Front Bumper Fascia is the plastic cover over your front bumper.
  5. You may also have to remove the plastic cover that is located under the front of the hood over the radiator.It extends to both sides.
Oct 27, 2009 | 2008 Chevrolet Malibu
Change headlight
hello. below is the procedure for removal of the headlamp for bulb replacement. to access the headlamp you will need to remove the bumper fascia. Callout Component Name 1 Front Compartment Sight Shield Plastic Retainers (Qty: 6) 2 Front Compartment Sight Shields (Qty: 3) Tip Each front compartment sight shield is serviced separately as needed for repairs Callout Component Name Preliminary Procedure Remove the front wheelhouse liner. Refer to Front Wheelhouse Liner Replacement . 1 Front Fascia Extension Plastic Retainers (Qty: 5) 2 Front Fascia Extension Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedures Remove the front compartment sight shields. Remove both front bumper fascia extensions. 1 Front Bumper Fascia Reinforcement Nut (Qty: 2) Tighten 6 N·m (53 lb in) 2 Front Bumper Fascia Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedure Remove the front bumper fascia. 1 Headlamp Nut (Qty: 1) Tighten 6 N·m (53 lb in) 2 Headlamp Bolts (Qty: 3) Tighten 6 N·m (53 lb in) 3 Headlamp Assembly
Jun 13, 2009 | 2003 Cadillac CTS
New Fascia?!
1-800-pioneer.Give out your model to the tech.,and he will tell you the part that you need.
Tuesday-Thursday between 7-8am would be the best time to call!
Nov 06, 2008 | Pioneer AVIC-X1R CD Player
Nokia 5310 fascia replacement
Here is a guide a wrote for replacing the front housing on a nokia 5310. It should be what you are looking for.
Nokia 5310 Front Housing Change
Hope that helps
Sep 21, 2008 | Nokia 5310 Cellular Phone
N76 fascia replacement
here's what your looking for just watch this
the upper block....
the lower block....
Nov 26, 2007 | Nokia N76 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
47 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
