Question about Compaq Presario 2100U Notebook
Boot problem Hi there. I'm having trouble in booting my notebook. When i switch on my notebook, it doesn't push thro to the system in order for the COMPAQ word appear in my monitor. How can i trouble shoot my notebook. Thanks.
  • 537 Answers
What comes up on your screen? Any boot up messages?
Check and make sure you do not have any CD-ROMS or USB or memory cards in your Presario 2100U when booting up. The system may be "stuck" because it doesn't know how do deal with those.
Mike
Posted on Oct 29, 2007
My little sisters dell inspiron mini just got the Unmountable boot volume message. I've looked online but most of the options require a cd which is of course not helpful when the mini doesn't have...
The best option is, look around for external cd-rom with usb connection, and reformat the laptop.You need to go into the bios and change the boot order to make your usb cd-rom to first in the boot list. Once the usb cd-rom is plugged into used port, with operation system cd in it, on your laptop..press F2..go into the bios, to the boot order make your usb cd-rom on top boot list,,then save changes to exit the bios. Once again the system reboots..with message PRESS ANY KEY TO BOOT FROM CD ROM.. so just simple steps to follow..its not going to be expensive..good luck
Sep 17, 2011 | Dell Inspiron Mini 10 Notebook
Where can i get a Toshibia L300 satelite Windows Vista Rebooting Disk to reset the laptop? as i cannot find the one that came in the package with the laptop.
Toshiba usually doesn't include the recovery as you would have to create one for yourself.
If you're having trouble finding it and you cannot boot the computer anymore my suggestion would be to contact toshiba and order a recovery disk. (it's part of their business and it sucks bigtime).
You can also create a windows installer using a USB you can youtube how to do it for video instructions.
If you can still boot from the computer go to control panel and that is where the program to create the recovery disks is.
Hope this helps!
Sep 11, 2011 | Toshiba Satellite Pro L300 Notebook
Non system disc or disc error fix
Hi, do you have a floppy disk, cd or usb stick inserted in your computer? Try removing such items and reboot as it may be trying to read these before the hard drive.
Check the boot order, when you first turn on your computer, access the BIOS menu (may need to push Delete, or one of the function keys eg F2, F8, F12 etc).
Check the boot order to ensure the correct hard drive it listed. Try moving the hard drive to the first option and reboot.
If removing any cd, usb stick etc doesn't help, try removing the hard drive and see if you can access it from another computer. If you can't access it, your operating system nay be corrupt and you may need to reformat.
Jul 28, 2011 | Intel Motherboard
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
Need to restore and cd drive is broken. Have a cd player accessed via usb port how do you point the system to the usb cd?
usually you can change the boot order to boot from a USB device. Press F2 (or could be DEL) to get into the BIOS menu after switch on (when prompted). Then look for the boot menu and change the boot order.
Jan 02, 2010 | Acer Aspire 6920 Notebook PC
Hi, I need to Format my Presario V2000 notebook but i'm not sure how to perform this action, can anyone please be able to help me ? Thanks Dan
Hi Dan,
O.k. You will need to use the recovery or operating system disc. At start up you will ned to boot from the CD, do this by either entering the boot menu and selecting the CD drive, or entering the bios/set up and changing the boot order to where the CD drive boots before the hard drive. Both of these actions are done at start up, there is an initial screen that prompts you to press a key in order to enter the boot menu or bios/set up. Once you have booted from the CD, you will follow the steps and it will guide you through the process.
Jul 18, 2008 | HP Compaq Presario V2000 Notebook
Gateway Laptop W350A
what memory board use gateway w350a
May 21, 2008 | Gateway M305CRV Notebook
Non System Disk or Disk error Replace and strike any key when ready
while switching on your system press F10 and the go to the Advanced setup. There you select and press Enter key on change boot order and then change the order by using Page up or page down key. Alternatively you may use Esc key while showing the compaq logo on boot, you will be able to change the Boot Order.
Feb 08, 2008 | Compaq Armada 7770DMT Notebook
Compaq Presario 2100U Notebook Logo
82 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
