Question about GE WJSR1070A Top Load Washer
Overflowed on Large load size
I have a GE washer and it overflowed when putting the water in (on large), but continued with the cycles. I re-set the load size, went back and did 2 more loads, one on Medium, the next one on large, and everything was fine, as I closely monitored it. I just moved it in, it is only 2 years old, I had it on it's side when moving, why did it overflow on a large load the first time and then not?
  • 5 more comments
  • annie8866 Oct 29, 2007
    I forgot to mention, I do one load on medium before this incident occurred.  But maybe the medium, wasn't enough to make it overflow?
  • annie8866 Oct 30, 2007
    I did 2 more loads again last night and everything seems to be ok, I think you are right!!
  • annie8866 Nov 16, 2007
    Last night I caught my washer over filling. When it initially fills it keeps filling up with water, starts spinning when it hits the appropiate level, but keeps filling. I couldn't stop it. Moved the dial so it would start draining, eventually it stopped after 5 minutes. But this only happens say every 12-15 loads or so. How do I fix it, everything else is fine.
  • annie8866 Nov 29, 2007
    My washing machine continully overflows as of now. When initially filling and during rinse 2 loads last night. I was going to first take the back off and check this air tube, if I need to clean it with what? I was also going to do a load tonight and unplug it, if it stops does that mean its not the fill valve?
  • Anonymous Jan 27, 2008
    i dont knowwhat to do is it the pump?
  • PhilwilFix Mar 22, 2009
    I have the same problem as Annie, except I've followed your posting advise and checked air filling tube-it's Ok, checked water filling valve and electrical input during cycles-Ok. I did replace the water level control switch because when setting was on low level, the water kept filling till it would have overflowed. Now the water leaks out some kind of moulded overflow tube attached the side of water tub. It goes all the way down past the bottom of tub and has a 90° bend on it with 1/2" hole in the end. This is where the water trickles out when cycling washer on the highest level only. Is this overflow tube suppose to have plug in the end of it? Or is it some kind of breather port for tub?
    Thanks, Phil
  • Anonymous Mar 19, 2014
    My Kitchenaid washer overflowed and now there is an awful smell coming from it. wHAT DO i DO TO GET IT OUT?
  • 883 Answers
I think the water level sensor tube got filled when you had it on it's side, then after the first spin and drain cycle, the tube was again cleared out and ready for real action.
Posted on Oct 29, 2007
  • 2 more comments
  • Marty marty Oct 30, 2007
    Great! Can you provide the solved rating now?
    Thank you.
    oh...I see you already did that...thanks again...I think my browser has failed to show the rating...
  • Marty marty Nov 16, 2007
    first must determine if the machine is falsely informing the valve to stay open. Do this with a voltmeter watching the valve signal across the valve electric terminals. If it is a false signal, then the machine's timer is a source of trouble. If machine signal is telling valve to close, then replace the valve...it is likely getting clogged with debris and sticking in open position.
  • Marty marty Nov 30, 2007
    Hi annie8866,
    when you said "...
    starts spinning when it hits the appropiate level, but keeps filling..." that says the water level switch is working properly and the valve is stuck open.
    when you said:
    "..eventually it stopped after 5 minutes. But this only happens say every 12-15 loads or so."...that says the valve is not ALWAYS sticking because it is not fully clogged with debris yet.
    when you said:
    "...My washing machine continully overflows as of now. When initially
    that mean its not the fill valve?"...that says the fill valve is getting worse (more debris) and the tube is for the level switch...don't bother unless you witness a false level sense...use a voltmeter across the switch terminals to watch for a signal change...if no change above desired level, then switch MAY be at fault or a pin hole has developed in tube...tube must be air-tight....before anything is done, try my other test "...voltmeter watching the valve signal across the valve electric terminals.".
The whirlpool washer overflowed and flooded the apartment
Need new pressureswitch or the pressure switch tube is not connected to tub or pressure switch itself!!! where it connects to tub at airdome might be plugged with dirt,soap ect!!!
Mar 15, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer just keeps filling and never advances on large and medium loads only
Your drain hose is pushed too far down into the drain so when you select the larger load sizes the water is being siphoned out as it goes in due to the pressure differential.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 01, 2012 | Electrolux Washing Machines
Washer overflowed after moving Load Capacity Switch from Super to reset and then to Large load?
On this model of washer you have 4 separate components that could cause overflowing. The water valve, pressure switch, pressure switch hose & the air dome. If you have to turn the water off to prevent overflowing, I would recommend replacing the water valve. If you can turn the timer off & the water stops overflowing, I would recommend checking the pressure switch, hose & air dome.
Jan 16, 2011 | GE Washing Machines
I just did a load of laundry at my mom's beach house. Second load so far is fine, however, first load seemed to leek from underneath. All water/drainage connections were dry. We moved and cleaned area and...
If all connections were dry, the water may have overflowed the top of the tub during a spin /rinse cycle. That could happen if there was a lot of water (i.e. set for large load) and a small amount of clothes.
Jul 08, 2009 | Washing Machines
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
Older hotpoint washer
Sounds like a pressure switch problem not a timer. depending on the year and model they had alot of water level problems.
Apr 18, 2008 | Washing Machines
Overflowing water
If the water comes out when filling, check your water valve by unplugging the washer when it is filling. If the water still runs, replace the valve. If the water stops, check the small tube that goes from the water pressure switch (in the consul) to the bottom of the tub. This must be connected without any holes or obstructions. If this is ok, replace the water pressure switch.
Jan 03, 2008 | GE WBSE3120B Top Load Washer
GE WJSR1070A Top Load Washer Logo
427 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
