I turned tv off then when I went to turn it on again there was nothing, I tried a different power lead from another tv but still will not turn on . I waited till the next day to try it but still nothing
Check and replace its main power supply regulator board. Contact any service technician.
Gopakumar Gopalan Google
SOURCE: tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Testimonial: "how helpfull thanku kindly !"
SOURCE: LG 32LP1D TV no power
Check the fuse on the power board. If ok change the power board.
Testimonial: "cheers man thats what it was."
SOURCE: totally dead. Vizio GV42L
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
SOURCE: TV wont turn on with power button or remote
Try putting the cables back where they were. After that re-route them again but this time use the manuel.
If that doesn't work, consult the TV's manuel.
SOURCE: tv won't turn on
KLV-32/40U100M (Dead, no lights), Solution, either replace or remove U24 uP reset chip on top of board, by (SW-1) silkscreen, I suspect, this is the common failure with dead units. Recommend
replacing U24, but should work fine without it. Why pay more!
