Sharp AQUOS LC-32D44U 32 in. LCD TV Logo
T
Terry Weltzer Posted on Mar 05, 2014
Green vertical lines across the screen.
I have green vertical lines across the screen I tried adjusting the sharpness, contrast, brightness etc. Reset to factory settings and also unplugged and turned back on, no change.
Wasatch Techies
Level 1:
New Friend:
  • Contributor 44 Answers
  • Posted on Mar 05, 2014
Wasatch Techies
Contributor
Level 1:
New Friend:
Answers
44
Questions
0
Helped
12691
Points
76
Green lines on LCD screens generally means physical damage. Did you drop it or bump it by chance? Physical could also include the cable that you are using. Try using a different cable, or make sure it is connected all the way.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
3 Related Answers
Anonymous
  • Posted on Sep 28, 2008
SOURCE: green vertical line on the right side of screen
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
Anonymous
  • Posted on Mar 15, 2010
SOURCE: My sharp aquos 32' LCD has a heavy green tint to
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
Anonymous
  • 308 Answers
  • Posted on Apr 11, 2010
SOURCE: screen filled with vertical lines
Put in a warranty claim.
What is OSD? have a white line moving back and forth across screen; previous fix said to reset from the OSD. not computer savvy so I don't know what this is. thanks.
An on-screen display (OSD) is a control panel on a computer monitor or television screen that allows you to select viewing options and/or adjust components of the display, such as brightness, contrast, and horizontal and vertical positioning. On a computer monitor, an on-screen display is usually activated by buttons on the bottom of the monitor.
Hello, I have a Dell U2711 monitor that now displays just a bright white screen. I was using the monitor, when it started getting brighter and developed a series of vertical lines in a repeating pattern...
Dell technical support number by dial Dell helpline number 1-80-243-0019 to get Dell customer support services to repair Dell Computer, Laptop, Printer.
Sharp lg-32bx6m, contrast light is not enough, how can i fix this problem
Select menu, display settings, select brightness/contrast/sharpness etc. and adjust these to your likings.
1helpful
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
1helpful
2answers
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
1helpful
Possibly needs a new control circuit board or lcd panel
24helpful
4answers
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
2answers
Color Adjustments....
well it all depends on where the tv is located to, if it is in a room with little or no light( windows, lamps) you will want you brightness to be a lil lighter hince not makin the picture as dark, and vise versa for light rooms, u'll wanna turn the brightness down a lil bit to accomidate this room, as for the others i'd say a lil over 50% on them, thats how my office tv is set up, hope this helps, jason
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
